StartUp and ShutDown errors
Hello everyone,
for the last week or so i have been getting some errors on startup and shutdown,
the PC works normally ( i have not noticed any lags, bugs, crashes etc).
Would you, based on the info below, think that there is something fishy going on with my nvme?
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=80a4f503-b50f-426e-96ca-364c2599304a rw rootflags=subvol=@
amdgpu.ppfeaturemask=0xffffffff ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4801
date: 03/02/2022
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2932 high: 3598 min/max: 2200/4467 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2880 2: 2878
3: 2878 4: 3500 5: 2870 6: 2878 7: 2878 8: 2879 9: 2200 10: 3598 11: 2878
12: 2877 bogomips: 84001
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DVI-D-1,HDMI-A-1,HDMI-A-2 bus-ID: 0d:00.0 chip-ID: 1002:687f
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Screen-1: 0 s-res: 3640x1920 s-dpi: 96 s-size: 963x508mm (37.91x20.00")
s-diag: 1089mm (42.87")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-r
model: AOC Q3279WG5B serial: <filter> built: 2019 res: 2560x1440 dpi: 90
gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9
modes: max: 2560x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-left
model: Samsung LF24T450F serial: <filter> built: 2023 res: 1080x1920 dpi: 93
gamma: 1.2 size: 296x527mm (11.65x20.75") diag: 604mm (23.8") ratio: 16:9
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Vega (vega10 LLVM
16.0.6 DRM 3.54 6.6.7-zen1-1-zen) device-ID: 1002:687f memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX Vega (RADV VEGA10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:687f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0d:00.1
chip-ID: 1002:aaf8 class-ID: 0403
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 08:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: b000 bus-ID: 09:00.0 chip-ID: 10ec:b822 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 0b05:185c
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.6 TiB used: 543.6 GiB (33.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Mushkin model: MKNSSDHL500GB-D8
lanes: 4 tech: SSD serial: <filter> fw-rev: R1115F0 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SP920SS size: 238.47 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: MU01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
used: 172.35 GiB (37.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 27.1 MiB (9.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 44.0 C mobo: 37.0 C gpu: amdgpu temp: 48.0 C
mem: 50.0 C
Fan Speeds (rpm): cpu: 605 case-1: 0 gpu: amdgpu fan: 3
Power: 12v: 9.97 5v: N/A 3.3v: N/A vbat: 3.25 gpu: amdgpu watts: 17.00
Processes: 338 Uptime: 29m wakeups: 0 Memory: total: 32 GiB
available: 31.26 GiB used: 4.93 GiB (15.8%) Init: systemd v: 255
Packages: 1975 pm: pacman pkgs: 1970 libs: 571 tools: octopi,paru
pm: flatpak pkgs: 5 Shell: fish v: 3.6.4 default: Bash v: 5.2.21
Garuda (2.6.21-1):
System install date:     2023-08-28
Last full system update: 2023-12-18 ↻
Journal errors
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT3._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO11._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT4._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO12._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT5._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO13._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT6._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO14._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT1._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT9._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT2._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO10._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT7._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO15._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT8._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO16._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO17._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO18._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO19._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO20._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO21._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO22._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:19 MarbleCannon kernel: nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000f address=0xffffc000 flags=0x0050]
Δεκ 18 11:54:
19 MarbleCannon kernel: nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000f address=0xffffc080 flags=0x0050]
Δεκ 18 11:54:20 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO10._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:20 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO12._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20230628/psparse-529)
Δεκ 18 11:54:22 MarbleCannon systemd-udevd[565]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Δεκ 18 11:54:31 MarbleCannon sddm-helper[5058]: gkr-pam: unable to locate daemon control file
Δεκ 18 11:54:35 MarbleCannon systemd[5061]: Failed to start BTRFS Assistant Snapper check.
Δεκ 18 11:55:52 MarbleCannon systemd[1]: Timed out waiting for device /dev/disk/by-uuid/ad608acf-e476-46f7-b85e-68e7b6c71d56.
Δεκ 18 11:56:06 MarbleCannon kernel: i2c i2c-9: Failed reset at end of transaction (01)
Δεκ 18 11:56:06 MarbleCannon kernel: i2c i2c-9: Failed! (01)
Δεκ 18 12:00:20 MarbleCannon systemd-udevd[565]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Δεκ 18 12:00:26 MarbleCannon (sd-pam)[52095]: pam_systemd(login:session): Failed to release session: Access denied
Δεκ 18 12:00:26 MarbleCannon (sd-pam)[52112]: pam_systemd(login:session): Failed to release session: Access denied
Δεκ 18 12:23:50 MarbleCannon sudo[245789]: juanpirate : a password is required ; TTY=pts/0 ; PWD=/home/juanpirate ; USER=root ; COMMAND=/usr/bin/true
Δεκ 18 12:23:55 MarbleCannon sudo[246069]: juanpirate : a password is required ; TTY=pts/0 ; PWD=/home/juanpirate ; USER=root ; COMMAND=/usr/bin/true
Have you tried different kernels say, the LTS?
Please reboot after installing them.
new message after lts
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT3._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO11._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT4._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO12._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT5._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO13._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT6._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO14._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT1._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT9._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT2._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO10._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT7._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO15._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT8._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO16._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO17._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO18._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO19._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO20._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO21._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO22._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:54 MarbleCannon systemd-modules-load[260]: Failed to find module 'v4l2loopback-dc'
Failed to find module 'vboxdrv'
Δεκ 19 12:54:54 MarbleCannon systemd-modules-load[260]: Failed to find module 'vboxnetadp'
Δεκ 19 12:54:54 MarbleCannon systemd-modules-load[260]: Failed to find module 'vboxnetflt'
Δεκ 19 12:54:54 MarbleCannon kernel: nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000f address=0xffffc000 flags=0x0050]
Δεκ 19 12:54:54 MarbleCannon kernel: nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000f address=0xffffc080 flags=0x0050]
Δεκ 19 12:54:55 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO10._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:55 MarbleCannon kernel: ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.PO12._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
Δεκ 19 12:54:57 MarbleCannon systemd-modules-load[621]: Failed to find module 'v4l2loopback-dc'
Δεκ 19 12:54:57 MarbleCannon systemd-modules-load[621]: Failed to find module 'vboxdrv'
Δεκ 19 12:54:57 MarbleCannon systemd-modules-load[621]: Failed to find module 'vboxnetadp'
Δεκ 19 12:54:57 MarbleCannon systemd-modules-load[621]: Failed to find module 'vboxnetflt'
Δεκ 19 12:54:57 MarbleCannon systemd-udevd[653]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Δεκ 19 12:55:06 MarbleCannon sddm-helper[5184]: gkr-pam: unable to locate daemon control file
Δεκ 19 12:55:08 MarbleCannon libddcutil[5664]: busno=5, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[DDCRC_ALL_RESPONSES_NULL in ddc_write_read_with_retry, causes: DDCRC_NULL_RESPONSE(4)]
Δεκ 19 12:55:09 MarbleCannon systemd[5187]: Failed to start BTRFS Assistant Snapper check.
Δεκ 19 12:55:12 MarbleCannon systemd-coredump[6205]: Process 6202 (vulkaninfo) of user 1000 dumped core.
                                                        Stack trace of thread 6202:
                                                        #0  0x00007f2a2938c1fa n/a (libvulkan_radeon.so + 0x18c1fa)
                                                        #1  0x00005570d9068406 n/a (vulkaninfo + 0x11406)
                                                        #2  0x00007f2a35245cd0 n/a (libc.so.6 + 0x27cd0)
                                                        #3  0x00007f2a35245d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                                        #4  0x00005570d906a705 n/a (vulkaninfo + 0x13705)
                                                        Stack trace of thread 6203:
                                                        #0  0x00007f2a352a74ae n/a (libc.so.6 + 0x894ae)
                                                        #1  0x00007f2a352a9d40 pthread_cond_wait (libc.so.6 + 0x8bd40)
                                                        #2  0x00007f2a2943746c n/a (libvulkan_radeon.so + 0x23746c)
                                                        #3  0x00007f2a29447fec n/a (libvulkan_radeon.so + 0x247fec)
                                                        #4  0x00007f2a352aa9eb n/a (libc.so.6 + 0x8c9eb)
                                                        #5  0x00007f2a3532e7cc n/a (libc.so.6 + 0x1107cc)
                                                        ELF object binary architecture: AMD x86-64
Δεκ 19 12:55:52 MarbleCannon systemd-coredump[11933]: Process 11930 (vulkaninfo) of user 1000 dumped core.
                                                         Stack trace of thread 11930:
                                                         #0  0x00007fc18718c1fa n/a (libvulkan_radeon.so + 0x18c1fa)
                                                         #1  0x000055b0c14f7406 n/a (vulkaninfo + 0x11406)
                                                         #2  0x00007fc193045cd0 n/a (libc.so.6 + 0x27cd0)
                                                         #3  0x00007fc193045d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                                         #4  0x000055b0c14f9705 n/a (vulkaninfo + 0x13705)
                                                         Stack trace of thread 11931:
                                                         #0  0x00007fc1930a74ae n/a (libc.so.6 + 0x894ae)
                                                         #1  0x00007fc1930a9d40 pthread_cond_wait (libc.so.6 + 0x8bd40)
                                                         #2  0x00007fc18723746c n/a (libvulkan_radeon.so + 0x23746c)
                                                         #3  0x00007fc187247fec n/a (libvulkan_radeon.so + 0x247fec)
                                                         #4  0x00007fc1930aa9eb n/a (libc.so.6 + 0x8c9eb)
                                                         #5  0x00007fc19312e7cc n/a (libc.so.6 + 0x1107cc)
Are you running VirtualBox?
This looks like a big mess of seemingly unrelated journal messages, most of which I don’t think you need to worry about if you aren’t having any specific problems.
These errors can be caused by a motherboard manufacturer being lazy with the spec, which is very common if the intent is to just make sure it will boot Windows and not look more closely than that. A lot of Linux systems have similar errors at every boot because of how the kernel finds and announces ACPI issues.
Check to see if there is a BIOS update available for your motherboard; that is the most appropriate way to get these errors resolved (if the vendor has addressed these issues, that is). Another thing you could try would be booting with acpi=off kernel parameter, although if you aren’t running into any actual issues I’m not sure I would even bother.
Do you have gnome-keyring installed for some reason? I believe that’s what gkr is in this case.
pacman -Qs gnome-keyring
Maybe it was installed but not properly configured, or maybe something else, I’m not sure. If you do some research you can probably figure out how to resolve this message or get it to stop, but probably it’s not anything to worry about.
I think this message seems more ominous than it is. I believe the “BTRFS Assistant Snapper check” is related to this autostart file at /etc/xdg/autostart/snapper-tools-check.desktop:
#!/usr/bin/env xdg-open
[Desktop Entry]
Exec=bash -c "grep -q .snapshots /proc/cmdline && sleep 3 && snapper-tools --autostart"
Icon=timeshift
Name=BTRFS Assistant Snapper check
Type=Application
X-GNOME-Autostart-enabled=true
X-KDE-autostart-after=panel
It checks if the string “.snapshots” is present in the kernel command line (it basically checks if you are booted into a snapshot), and if so runs snapper-tools --autostart. Since you are not booted into a snapshot, the command won’t be executed (it gets an exit code before it gets to the first &&). This is the expected behavior since the command is designed to run conditionally.
My guess is if you boot into a snapshot, you will not see this failure reported in the log and the snapper-tools command would be run instead.
What is this device? Something in /etc/fstab? Why is systemd looking for it? If it is not something you need mounted you could try to track it down and take it out of fstab, or where ever else in systemd land the attempted mount is coming from.
From what I understand, the I2C bus is a communication protocol related to devices communicating with each other. It looks like you have a problem with bus 9. It could be a hardware issue like a bad connection, or it could be a driver or kernel issue…it could be any number of devices using bus 9, like sensors or controllers or anything really. Who knows!
Again, if you are not having any specific issue I wouldn’t worry about it.
I would say maybe don’t use that kernel. :sweat_smile:
In general I think if you aren’t having issues with the system, no need to go digging through the journal trying to figure out what every little message means. Get your BIOS up to date (:wink:), and other than that I don’t see any cause for alarm here.
Turns out something went wrong with my quiet setting on GRUB and things escalated from there! Thank you for your help and the information! I will try to see if i can fix some of the errors if i get the time!
What did you do to fix it exactly? This happened to my system after the last kernel update… same kind of errors at boot and shutdown that you were getting. You said it’s grub, so I’m guessing that update changed something in my grub too.
Probably the messages were always there, but not visible until:
You can configure a silent boot like so: Silent boot - ArchWiki
TL;DR: add these kernel parameters:
quiet loglevel=3 systemd.show_status=auto rd.udev.log_level=3
An easy way to add them would be in Garuda Boot Options, add them to the parameters line and click Apply.
I apologize. I actually thought they would help you. Maybe it’s too early or too late.
I’ll never understand why intelligent creatures fall into coma at nightfall.
Um…huh?
Must have been a joke. Please don’t be resentful :blush:
Blaming a translation application is always in fashion. :wink:
Sing ken ken :sunglasses:
Ah thank you. Yeah the last grub update did some weird stuff, it commented out splash and put quiet twice. All back to normal now.
