System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=622586c4-6f82-4957-a50c-3aa9ab09c772 rw rootflags=subvol=@ quiet splash
Desktop: Cinnamon 5.0.7 tk: GTK 3.24.30 wm: muffin vt: 7 dm: LightDM 1.30.0
Machine: Type: Laptop System: LENOVO product: 82JY v: Legion 5 17ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 17ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required>
UEFI: LENOVO v: GKCN46WW date: 10/01/2021
Battery: ID-1: BAT0 charge: 82.8 Wh (100.0%) condition: 82.8/80.0 Wh (103.5%) volts: 16.7
min: 15.4 model: Celxpert L20C4PC2 type: Li-poly serial: <filter> status: Full
cycles: 4
CPU: Info: 6-Core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000C cache:
L1: 384 KiB L2: 3 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 79050
Speed: 1722 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz): 1: 1722
2: 2530 3: 2217 4: 2797 5: 3220 6: 1499 7: 4049 8: 2794 9: 3211 10: 1794 11: 2087
12: 3177
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling
Graphics: Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2560 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DP-4 res: 1920x1080 hz: 144 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:228e
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 520.27 GiB used: 42.08 GiB (8.1%)
model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 21160001
temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: DT microDuo 3.0
size: 28.88 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: USB FLASH DRIVE
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
Partition: ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 24.81 GiB (49.6%) fs: btrfs
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 28.9 MiB (11.3%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 50 GiB size: 50 GiB (100.00%) used: 24.81 GiB (49.6%) fs: btrfs
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%) used: 24.81 GiB (49.6%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%) used: 24.81 GiB (49.6%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 2.2 MiB (0.0%) priority: 100
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 363 Uptime: 7m wakeups: 1 Memory: 15.54 GiB used: 3.26 GiB (21.0%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1420 lib: 336 Shell: Zsh v: 5.8 running-in: alacritty inxi: 3.3.09
Hello! I recently moved to Garuda Cinnamon and stumbled across a very strange issue; attempting to start Audacity causes the entire system to freeze, i.e. frozen screen, looping sound (if any), no TTYs or REISUB. I even tried enabling sshd to check if I could connect after the freeze. Only cutting the power works. I also installed rsyslog, all logs seem normal. How can I even troubleshoot this any further? How could a program cause such problems? I still have my old installation (KDE Dragonized) in another partition, if that's of any help.
Edit: Memory usage seems fine while running Audacity. I tried reinstalling Audacity too.
