Hello
I have a server with SSH enable. It is install with “lukas”. If I connect with lukas I have the normal shell and I can do what I want.
With my user “youtube” I have this:
I cannot go to the last command with arrow up. That is ultra weird. I add the user via CLI. I don’t know exactly to explain this
Kernel: 6.10.2-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9bdc1bb8-710e-4a2b-a1fc-d771d79d9fb1 rw rootflags=subvol=@
quiet splash amd_iommu=on ibt=off
Desktop: Cinnamon v: 6.2.7 tk: GTK v: 3.24.43 wm: Muffin v: 6.2.0 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: CROSSHAIR VI HERO v: Rev 1.xx
serial: <superuser required> part-nu: SKU UEFI: American Megatrends v: 7704
date: 12/16/2019
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2429 high: 4454 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1977 2: 4448
3: 2106 4: 2200 5: 1977 6: 2125 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2199 14: 3727 15: 4454 16: 2701 17: 1978 18: 2007 19: 2200
20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 182406
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: DP-2,HDMI-A-1,HDMI-A-2
empty: DP-1,DVI-D-1 bus-ID: 0b:00.0 chip-ID: 10de:1b81 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: CardExpert
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-3,
DP-4, DP-5, DVI-D-2, HDMI-A-3 bus-ID: 0c:00.0 chip-ID: 10de:1b81
Device-3: Logitech StreamCam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:2 chip-ID: 046d:0893
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.60x11.85")
s-diag: 1618mm (63.71")
Monitor-1: DP-2 mapped: DP-3 note: disabled pos: primary,center
model: BenQ GL2450H serial: <filter> built: 2015 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Dell SE2422H serial: <filter> built: 2022 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
Monitor-3: HDMI-A-2 mapped: HDMI-1 note: disabled pos: left
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: nvidia device: 4 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
x11: drv: nvidia inactive: wayland,device-2,device-3
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 555.58.02
device-ID: 10de:1b81 surfaces: xcb,xlib device: 1 type: discrete-gpu
device-ID: 10de:1b81 surfaces: N/A
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: CardExpert
link-max: lanes: 16 bus-ID: 0c:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: RODE Microphones NT-USB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3
chip-ID: 19f7:0003 class-ID: 0300
Device-5: Logitech StreamCam
API: ALSA v: k6.10.2-zen1-2-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Local Storage: total: 6.37 TiB used: 789.13 GiB (12.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QGXA7
temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA723020ALA641
tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: GPT
model: WD10EFRX-68PJCN0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EADS-00M2B0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A01
scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
used: 789.13 GiB (88.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
System Temperatures: cpu: 57.0 C mobo: 30.0 C gpu: nvidia temp: 54 C
Fan Speeds (rpm): cpu: 1442 case-1: 0 case-2: 1201 case-3: 0 gpu: nvidia
fan: 0%
Power: 12v: 12.23 5v: N/A 3.3v: N/A vbat: 3.18
Memory: total: 32 GiB available: 31.27 GiB used: 10.13 GiB (32.4%)
Processes: 541 Power: uptime: 1h 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 2190 libs: 623 tools: paru,yay Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.35
System install date: 2024-01-20
Last full system update: 2024-08-04
