Spontaneously Freezing up
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b490211f-2fe3-40fa-bb09-ede6ca56b7ae rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS X HERO (WI-FI AC) v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 2503
date: 09/25/2020
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 801 high: 817 min/max: 800/4700:5000 scaling:
5: 817 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 801 bogomips: 88796
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DVI-D-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Device-2: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4
chip-ID: 045e:075d class-ID: 0102
compositor: kwin_x11 driver: X: loaded: nvidia
unloaded: modesetting,nouveau,vesa alternate: fbdev,nv
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 159 s-size: 1227x352mm (48.31x13.86")
s-diag: 1276mm (50.26")
Monitor-1: DP-2 note: disabled pos: right model: Samsung U28E590
serial: <filter> built: 2018 res: 3840x2160 hz: 60 dpi: 161 gamma: 1.2
size: 607x345mm (23.9x13.58") diag: 698mm (27.5") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,left
model: Samsung U28E570 serial: <filter> built: 2018 res: 3840x2160 hz: 30
dpi: 160 gamma: 1.2 size: 608x345mm (23.94x13.58") diag: 699mm (27.5")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1080 driver: nvidia v: 545.29.06
device-ID: 10de:1b80 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13:5 chip-ID: 0b05:185c
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 5.46 TiB used: 437.71 GiB (7.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 31.9 C scheme: MBR
model: WD5000AAKS-00V1A0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
model: WD4004FZWX-00GBGB0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A81 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
used: 119.34 GiB (12.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 55 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 24%
Processes: 376 Uptime: 3m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.83 GiB (15.4%) Init: systemd v: 254
pm: pacman pkgs: 1971 libs: 571 tools: octopi,pamac,paru,yay pm: flatpak
pkgs: 0 Shell: fish v: 3.6.1 running-in: yakuake inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-07-07
Last full system update: 2023-12-02
Relevant software:       timeshift(custom) NetworkManager dracut nvidia-dkms
Over the last few days, I’ve had my system just freeze.
Not sure if it’s hardware or software and before I do a reinstall, is there somewhere I can find a log that might show the issue at the time it freezes after I get rebooted?
I did try the Zen and LTS kernels over the last week and had the freezing on both kernels, so it’s not the kernel.
Bios is updated and slightly OC’d but has been for months
Looks like a reinstall coming. Besides the Freezeups, suddenly, one of my drives won’t mount;
(An error occurred while accessing ‘D: Drive’, the system responded: The requested operation has failed: Error mounting /dev/sdb2 at /run/media/hipkat/D: Drive: wrong fs type, bad option, bad superblock on /dev/sdb2, missing codepage or helper program, or other error).
Works fine when I switch to the Windows Drive.
Anytime I come out of sleep, the monitors don’t come on and I have to hard reboot the computer.
I know I need to renew my thermal paste. HWInfo on Windows shows CPU temps peaking @ 68° C but averaging about 38°
I’ll wait and see if you have ideas but I’m not a hardcore Linux programmer - although I’m decent with understanding many things.
I have experienced freezes in the past that were the result of a bad hard drive. This occurred even though smartmon testing said it was fine. You definitely, want to run some integrity checks on your drive. The drive may not be experiencing a hardware failure, it may simply have become corrupted. If this is a Windows drive/partition then it is best to try to correct the errors using the Windows specific tools. If there is also a Linux filesystem on another partition, then you should consult the Arch Wiki for the procedure to correct any Linux filesystem errors. If your partition table has been corrupted then you will need to use a Linux or Windows file recovery program to hopefully recover the drive geometry and allow the drive to become readable again.
Data recovery is really out of the scope of the Garuda forum, but you could try using the freeware Linux program testdisk as a recovery option. Windows recovery software options are usually expensive, so be prepared to shell out a fair bit of money if that is your only option.
You can check your journalctl logs, but it is rare that a complete freeze (KB, cursor & terminal are dead) will show the the actual cause of the freeze. That is why these types of issues can be so hard to diagnose. If the computer is completely locked up all journal entries stop when the freeze occurs.
For troubleshooting purposes you should really revert your system to the factory recommended clocking, (undo any custom overclocking).
The drive that’s not mounting is a storage Drive. I checked it with Windows and found no errors.
The Garuda install is on a M.2 Drive. I have Win 11 on a SATA SSD. I also have another HDD which is formatted and a 4TB EHD. Chkdsk detects no errors in any drives.
I just think with all the update issues over the last few months, something has been corrupted but in the file system,
I backed up the important stuff in my Home folder so a reformat and reinstall shouldn’t take more than about an hour or so.
The bummer is that I’ve been running this build for about 2 years now :frowning:
I’m going to take your advice and load the default settings on the Bios on next boot and see how that goes
When I check journalctl --system I fo find some random errors. but I’m not sure what they mean.
Here’s a few
For example
Dec 03 20:14:54 greg-garuda kernel: nvidia: loading out-of-tree module taints kernel.
Dec 03 20:14:54 greg-garuda kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 03 20:14:54 greg-garuda kernel: Disabling lock debugging due to kernel taint
Dec 03 20:14:54 greg-garuda kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Dec 03 20:14:54 greg-garuda kernel: nvidia: module license taints kernel.
Dec 03 20:14:54 greg-garuda kernel: pcieport 0000:00:1c.6: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Dec 03 20:14:54 greg-garuda kernel: pcieport 0000:00:1c.6:   device [8086:a296] error status/mask=00000001/00002000
Dec 03 20:14:54 greg-garuda kernel: pcieport 0000:00:1c.6:    [ 0] RxErr                  (First)
Dec 03 20:14:54 greg-garuda kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags >
The Nvidia kernel taint errors can be ignored. They simply reference the fact that using non free Nvidia drivers makes you some sort of tainted leper. :rofl:
The pciport errors look like they can be rectified with this method from the Arch forum:
https://bbs.archlinux.org/viewtopic.php?id=241473
That solution was easily located by searching the pciport error message from your log.
Same deal below, easily located by searching the error message:
https://bbs.archlinux.org/viewtopic.php?id=272497
Thanks TBG.
I haven’t even researched them yet, as it was getting late here but neither of those seem to be a big deal. TPM is only enabled for the Win11 Drive. It doesn’t seem like the USB 3.1 error eans much either.
Next time it freezes, on reboot I can pull the journal and see what the error was right before it froze
