From System Settings>Appearance>Global Theme>Splash Screen I chosed a splash screen which is showed when i start my machine. While shutting down I can't see any splash screen. Screen goes out and come back, Panels and docks vanishes, just my desktop, or if i have any window opened then that window and then machine goes off like boom. like why this awkward screen, sometimes i get confused if the restart is already done. I couldn't find any settings to chose a shutdown splash.
OS: Garuda Gaming (KDE)
(i'll add further system info if needed)
Please share output inxi -Faz
as text.
Ideally, there should be no need to have splash screen on shutdown, because shutdown is very instantaneous.
System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9defb73e-3680-499e-89ec-10d7b12843a5
systemd.unified_cgroup_hierarchy=1 amdgpu.ppfeaturemask=0xffffffff
resume=UUID=922b6371-e6a5-4c9a-beae-5a05f7ce4b41 loglevel=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Gigabyte model: B450M S2H v: x.x serial: <filter> UEFI: American Megatrends
v: F50 date: 11/27/2019
CPU: Info: Quad Core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701013 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57490
Speed: 2195 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2195 2: 2194
3: 1862 4: 2795 5: 2195 6: 2197 7: 2195 8: 2190
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Sapphire Limited
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 75 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0 5.15.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
Device-3: JMTek LLC. FANTECH CAPTAIN 7.1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-1:2 chip-ID: 0c76:16cb class-ID: 0300
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus-ID: 1-4.1:3 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 1.14 TiB used: 511.7 GiB (43.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000PNP size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: V9002s34 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
serial: <filter> rev: CC43 scheme: GPT
Partition: ID-1: / raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 73.77 GiB (33.4%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 73.77 GiB (33.4%) fs: btrfs
ID-4: /var/log raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 73.77 GiB (33.4%)
ID-5: /var/tmp raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 73.77 GiB (33.4%)
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.63 GiB used: 1.1 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 848
Info: Processes: 317 Uptime: 1h 3m wakeups: 0 Memory: 15.63 GiB used: 3.15 GiB (20.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1864 lib: 514
flatpak: 0 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
That model has an bios update available. (Unrelated to topic anyway)
Except that, your Machine should work perfectly fine and smoothly.
Can you share a video of your pc at shutdown (uploaded on youtube/vimeo/ other platform) to let me understand better what exactly is your concern.
can't record while shutting down. shutdown gets canceled by recorder.
anyway not a major issue.
You can use your smartphone to record.
Try the LTS kernel and see if it is a bit smoother, is where I'd go with it.
