Spectacle not launching error while loading shared libraries: librav1e.so.0
getting this when running spectacle
spectacle: error while loading shared libraries: librav1e.so.0: cannot open shared object file: No such file or directory
  Kernel: 6.5.6-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-linux
    root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw rootflags=subvol=@
    sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
    nmi_watchdog=0 initrd=@\boot\initramfs-linux-cachyos.img
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
    UEFI: American Megatrends v: P5.10 date: 10/20/2022
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4473 high: 4575 min/max: 2200/4650 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 4574 2: 4575
    3: 3899 4: 4575 5: 4575 6: 4575 7: 4575 8: 4574 9: 4061 10: 4554 11: 4575
    12: 4573 bogomips: 88805
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1
    bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
    gpu: amdgpu d-rect: 4980x2513 display-ID: 0
  Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
  Monitor-2: DP-2 pos: primary,top-left res: 1396x785 size: N/A modes: N/A
  Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
    16.0.6 DRM 3.54 6.5.6-1-cachyos) device-ID: 1002:73df memory: 11.72 GiB
    unified: no display-ID: :0.0
  API: Vulkan v: 1.3.264 layers: 19 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Sony INZONE H9 / H7
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:3 chip-ID: 054c:0e53
    class-ID: 0a00
  API: ALSA v: k6.5.6-1-cachyos status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
  Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 7392:c611
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 7c0104
  Device-2: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 8087:0aa7
  Report: ID: hci1 rfk-id: 2 state: up address: <filter> bt-v: 4.2 lmp-v: 8
    status: discoverable: no pairing: yes class-ID: 7c0104
  Local Storage: total: 2.96 TiB used: 2.4 TiB (81.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 40.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 35.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
    used: 838.62 GiB (90.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
    used: 29.8 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
  System Temperatures: cpu: 73.5 C mobo: 35.0 C gpu: amdgpu temp: 50.0 C
    mem: 52.0 C
  Fan Speeds (rpm): cpu: 2749 fan-1: 0 fan-3: 0 fan-4: 0 fan-5: 1499
    gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.18 vbat: 3.28 gpu: amdgpu watts: 31.00
  Processes: 551 Uptime: 0m wakeups: 2 Memory: total: 32 GiB
  available: 31.26 GiB used: 12.79 GiB (40.9%) Init: systemd v: 254
  Packages: 2771 pm: pacman pkgs: 2728 libs: 605 tools: octopi,paru
  pm: appimage pkgs: 0 pm: flatpak pkgs: 43 Shell: fish v: 3.6.1
  running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-09-26
  Last full system update: 2023-10-11
figured it out version 0.6.6-3 of rav1e was causing the issue downgrading back to 0.6.6-2 fixed it
Please mark your reply as a solution :white_check_mark: , and close this issue .
Not really a solution as it’s not a good idea to keep the package downgraded plus it doesn’t seem to be a packaging issue with arch as others have confirmed it doesn’t happen on vanilla Arch…
I disagree , it can happen from time to time , This is a post in reddit from someone encounter it in KDE neon distro (ubuntu based and maintained by KDE themselves).
I will advise you that don’t update your system every minute or hour , just try to keep it less update as much as possible (like every day or a while), Garuda and its repo trying to make it stable as much as they can , but it does not mean its like debian based .
I talked to arch people they said they have spectacle working with 0.6.6-3 of rav1e
(Even showed a screenshot of spectacle working with the latest rav1e installed)
I posted here and in the Garuda telegram in hopes of finding a Garuda user who can confirm or deny this issue also happens to them.
Arch users at least don’t have the issue.
It could be something specific to my system
I checked if the file exists and it does…
Restored from a snapshot before the update and re did the update. Fixes the issue so I guess something went wrong with the initial update.
I don’t think it was that a package update as I did try updating before restoring the backup…
