Sound problem combo jack (sof-essx8336)
Hello everyone! I have a problem with Linux on my laptop. In the settings, it shows as if the headphones are plugged in (even though they are not) and tries to output sound to them. However, if I actually plug in the headphones, the system thinks they are disconnected and tries to play sound through the built-in speakers, but even then there is no sound.
The headphone jack is a combo jack, intended for both headphones and microphone. This problem, at least, is observed in Arch Linux, I haven’t tried other distributions yet. Everything worked fine on my previous laptop, the connectors were separate.
I would appreciate any help or advice on how to solve this problem!
Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=cefc901d-899e-4227-ac56-024b0024718a rw rootflags=subvol=@
quiet resume=UUID=540abb98-296e-437f-b5e2-c02cd1a51ffa loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: Echips Import LLC product: Echips Special [NQ11A]
v: N/A serial: <superuser required>
Mobo: Echips Import LLC model: Echips Special [NQ11A]
serial: <superuser required> part-nu: Echips Special [NQ11A]
uuid: <superuser required> UEFI: Echips Import LLC
v: YK-BI-14-XU133ER400-EE60A-001-I date: 05/19/2023
ID-1: BAT0 charge: 44.2 Wh (96.9%) condition: 45.6/45.6 Wh (100.0%)
power: 17.1 W volts: 12.8 min: N/A model: Intel SR 1 SR Real Battery
type: Unknown serial: <filter> status: charging
Info: model: Intel Core i3-8109U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 905 high: 920 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 920 4: 900
bogomips: 24000
Device-1: Intel CoffeeLake-U GT3e [Iris Plus Graphics 655] driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea5 class-ID: 0300
Device-2: Microdia Hy-UXGA(2601)-Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4
chip-ID: 0c45:636c class-ID: 0102 serial: <filter>
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Plus Graphics 655
(CFL GT3) device-ID: 8086:3ea5 memory: 3.74 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
Iris Plus Graphics 655 (CFL GT3) driver: mesa intel v: 24.1.2-arch1.1
device-ID: 8086:3ea5 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Cannon Point-LP High Definition Audio
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0401
API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 8086:15f3
driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
IF-ID-1: enp0s20f0u3 state: unknown speed: -1 duplex: half mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 0bda:c821
Device-2: MediaTek 2207117BPG driver: rndis_host v: kernel type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:7 chip-ID: 0e8d:2004
Local Storage: total: 238.47 GiB used: 11.95 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gateway model: W800S 256GB
tech: SSD serial: <filter> fw-rev: 3G5A scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 11.94 GiB (5.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 64.0 C pch: 47.0 C mobo: N/A
Memory: total: 8 GiB available: 7.66 GiB used: 5.09 GiB (66.5%)
Processes: 239 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1313 libs: 383 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date:     2024-06-23
Last full system update: 2024-06-24
This can happen after a suspense or hibernation, I had this at least.
Can you try running?
sudo udevadm trigger
This might help.
No, it didn’t work :slightly_frowning_face:
