Line-out(Back panel port) and Headphone (Front panel port) works fine when single output device is connected. But, if i connect 2 devices in those ports, only get output from Headphone. Even i switch my output to lineout from settings none of my devices give output. Changing back to headphone gives output from headphone.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_AG",
LC_NAME = "en_AG",
LC_MONETARY = "en_IN.UTF-8",
LC_PAPER = "en_AG",
LC_IDENTIFICATION = "en_AG",
LC_TELEPHONE = "en_AG",
LC_MEASUREMENT = "en_AG",
LC_TIME = "en_AG",
LC_NUMERIC = "en_AG",
LANG = "en_IN.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d4caa672-6541-4f13-b9be-56090e71fea4 rw rootflags=subvol=@
Type: Desktop Mobo: INTEL model: B75 serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 12/30/2020
Info: model: Intel Core i5-3570K bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v3 built: 2012-15 process: Intel 22nm family: 6
desc: 1x6 MiB
Speed (MHz): avg: 1629 high: 1675 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1649 3: 1675
4: 1596 bogomips: 27137
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ZOTAC driver: nvidia
v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 650x366mm (25.59x14.41")
s-diag: 746mm (29.37")
Monitor-1: DVI-I-0 res: 1920x1080 hz: 60 size: N/A modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 16.1 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 2-1.5:3 chip-ID: 0bda:8179 class-ID: 0000
IF: wlp0s29u1u5 state: up mac: <filter>
Local Storage: total: 223.57 GiB used: 18.7 GiB (8.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 054 scheme: GPT
ID-1: / raw-size: 35 GiB size: 35 GiB (100.00%) used: 18.68 GiB (53.4%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 20.1 MiB
(20.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 35 GiB size: 35 GiB (100.00%) used: 18.68 GiB
(53.4%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 35 GiB size: 35 GiB (100.00%) used: 18.68 GiB
ID-5: /var/tmp raw-size: 35 GiB size: 35 GiB (100.00%) used: 18.68 GiB
ID-1: swap-1 type: zram size: 7.72 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 223 Uptime: 2m wakeups: 0 Memory: 7.72 GiB used: 1.91 GiB
(24.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1451 libs: 379
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-08-08
Last full system update: 2022-10-02
