Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC driver=nonfree nouveau.modeset=0
i915.modeset=1 radeon.modeset=1 misobasedir=garuda
misolabel=GARUDA_GNOME_SOARING_ quiet systemd.show_status=1 splash
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Garuda Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx
v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87B2 v: 31.20 serial: <filter> UEFI: AMI v: F.11
date: 07/22/2020
ID-1: BAT0 charge: 26.6 Wh condition: 52.9/52.9 Wh (100%) volts: 11.3/11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: Discharging cycles: 475
Device-1: hidpp_battery_0
model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 71928
Speed: 1915 MHz min/max: 1400/3000 MHz boost: disabled Core speeds (MHz):
1: 1915 2: 2420 3: 2420 4: 2122 5: 2117 6: 2420 7: 1913 8: 2419 9: 1389
10: 1382 11: 1383 12: 1382
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f95
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:1636
Device-3: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB
driver: uvcvideo bus ID: 3-3:3 chip ID: 30c9:0013 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell
driver: amdgpu,nvidia unloaded: modesetting
alternate: ati,fbdev,nouveau,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.4-107-tkg-bmq LLVM 11.0.0)
v: 4.6 Mesa 20.3.2 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 05:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:2723
Local Storage: total: 505.59 GiB used: 1.15 GiB (0.2%)
model: PC SN530 SDBPNPZ-512G-1006 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: HPS2 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Ultra Fit
size: 28.65 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: 1.00
ID-1: / raw size: N/A size: 5.4 GiB used: 1.15 GiB (21.3%) fs: overlay
source: ERR-102
ID-1: swap-1 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-9: swap-9 type: zram size: 614.5 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram8
ID-10: swap-10 type: zram size: 614.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 614.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 614.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram11
System Temperatures: cpu: 41.9 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 324 Uptime: 12m wakeups: 4 Memory: 7.2 GiB
used: 4.17 GiB (58.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1203 lib: 289 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
I just installed Garuda on my laptop and for some reason no audio plays and I cannot adjust the volume of the sound at all. Is there a fix for this?
Edit : I have not faced this issue in the KDE edition of Garuda. It only seems to happen in the GNOME edition.
