Sound in garuda
When you listen to music in garuda on headphones for a long time, and then switch to stereo speakers, then the sound comes from only one speaker. Two speakers start working only when you turn the speakers off and on again. I noticed this only in garuda. On other distributions, everything is fine with the sound. pipewire.
Kernel: 6.10.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=26f8914e-9f6c-42dd-b036-8c3185677b13 rw rootflags=subvol=@
quiet resume=UUID=797efa7f-fc55-435a-8ea7-da88c07000d4 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
Megatrends LLC. v: 2.K0 date: 10/20/2023
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2906 high: 3615 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2800
3: 3600 4: 3615 5: 3205 6: 2368 7: 2569 8: 2068 9: 2200 10: 3496 11: 3157
12: 2200 bogomips: 86402
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: eVga.com.
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 26:00.0 chip-ID: 10de:2488
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia display-ID: 0
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 560.35.03
device-ID: 10de:2488 surfaces: xcb,xlib,wayland
Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: ASUSTek TUF GAMING H5/H7
lanes: 1 mode: 1.1 bus-ID: 1-10:2 chip-ID: 0b05:189c class-ID: 0300
API: ALSA v: k6.10.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.47 TiB used: 1.06 TiB (71.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: AMD Radeon model: R5MP120G8
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103F0L temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN750 SE 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 32.9 C scheme: GPT
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 54.98 GiB size: 54.98 GiB (100.00%)
used: 23.96 GiB (43.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /home raw-size: 394.53 GiB size: 394.53 GiB (100.00%)
used: 338.54 GiB (85.8%) fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:9
ID-4: /var/log raw-size: 54.98 GiB size: 54.98 GiB (100.00%)
ID-5: /var/tmp raw-size: 54.98 GiB size: 54.98 GiB (100.00%)
ID-2: swap-2 type: partition size: 15.96 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 41.4 C mobo: N/A
Memory: total: 16 GiB available: 15.54 GiB used: 2.84 GiB (18.3%)
Processes: 421 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: 1568 pm: pacman pkgs: 1551 libs: 480 tools: octopi,paru
pm: flatpak pkgs: 17 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-08-03
Last full system update: 2024-09-05 ↻
Don’t forget to post your garuda-inxi before asking for help
Reboot, please.
