inxi -Fxxz
Kernel: 5.11.6-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: GNOME 3.38.3 tk: GTK 3.24.27 wm: gnome-shell dm: GDM Distro: Garuda Linux
Type: Laptop System: Acer product: TravelMate P243 v: V1.06 serial: <filter>
Mobo: Acer model: BA40_HC v: Type2 - Board Version serial: <filter>
UEFI [Legacy]: Insyde v: 1.06 date: 08/09/2012
ID-1: BAT1 charge: N/A condition: N/A volts: 7.8/11.1 model: SANYO AS10D31
serial: <filter> status: Unknown
Info: Dual Core model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19156
Speed: 2311 MHz min/max: 1200/2400 MHz Core speeds (MHz): 1: 2311 2: 2091 3: 2029
4: 2026
Device-1: Intel 3rd Gen Core processor Graphics vendor: Acer Incorporated ALI
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Display: wayland server: X.Org 1.21.0.99 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa resolution: 1366x768~60Hz
s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.4
compat-v: 3.0 direct render: Yes
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1e20
Sound Server: ALSA v: k5.11.6-zen1-1-zen
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000 bus ID: 04:00.2
chip ID: 10ec:8168
IF: enp4s0f2 state: down mac: <filter>
Device-2: Broadcom BCM43228 802.11a/b/g/n vendor: Foxconn driver: wl v: kernel
port: 2000 bus ID: 09:00.0 chip ID: 14e4:4359
IF: wlp9s0 state: up mac: <filter>
Local Storage: total: 465.76 GiB used: 46.23 GiB (9.9%)
ID-1: /dev/sda vendor: Western Digital model: WD5000BPVT-22A1YT0 size: 465.76 GiB
speed: 3.0 Gb/s serial: <filter>
ID-1: / size: 465.76 GiB used: 46.23 GiB (9.9%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 465.76 GiB used: 46.23 GiB (9.9%) fs: btrfs dev: /dev/sda1
ID-3: /var/log size: 465.76 GiB used: 46.23 GiB (9.9%) fs: btrfs dev: /dev/sda1
ID-4: /var/tmp size: 465.76 GiB used: 46.23 GiB (9.9%) fs: btrfs dev: /dev/sda1
ID-1: swap-1 type: zram size: 2.39 GiB used: 256 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 2.39 GiB used: 256 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 2.39 GiB used: 256 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 2.39 GiB used: 256 KiB (0.0%) priority: 32767
dev: /dev/zram3
System Temperatures: cpu: 69.0 C mobo: N/A
Processes: 247 Uptime: 1h 50m Memory: 9.57 GiB used: 4.11 GiB (42.9%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1318 Shell: fish
v: 3.1.2 running in: gnome-terminal inxi: 3.3.0
Here is my python coding for generating simple window.
import sys
from PyQt5.QtWidgets import *
class Window(QWidget):
def __init__(self):
super().__init__()
self.setGeometry(1000, 100, 300, 400)
self.setWindowTitle('Main Window.')
self.show()
App = QApplication(sys.argv)
window = Window()
sys.exit(App.exec_())
Here , in self.setGeometry function, (1000, 100) represent window position on desktop and (300, 400) represent window size. So, my problem is the window size (300, 400) gives result properly. But window position co - ordinate (1000, 100) is no affecting the position of window.
The two screenshots illustrating my words given below:
1.
2.The position is same but size is different. Even I changed (1000, 100) to (1,1)
I think, may be OS parameters overriding the window position parameter of my program.!!!!!
