Hello,
I have multiple branded CDs. But only few are being detected but others are not getting detected. I hope the issue with the code.
I can assure you that CD driver is working normally. Because other CD's EMERY brand) are getting detected in the same moment. But others like SONA, POWER brands are not.
It is more probably the issue with the CD itself. Because if the cd driver is working for some cd, it is not its fault. It is most probably the cd that is faulty.
Hey thanks for your reply. I have purchased 7 CD's, only 2 of them are opening in Garuda and remaining 5 are not. Meantime, all of the CD's are working fine in Windows systems.
No, Not Blank. All CD's are already burnt and i have purchased from an edu materials seller. I just want to copy the contents to my system. But its not getting detected.
Out of 7 CD's purchased, 2 were detected and i had completed copy paste work and the remaining 5 were not detected. I don't know where is the problem.
You posted 2 separate replies today, yet you have still not posted your inxi -Faz output as requested. This information is crucial to helping find a solution. We do not even know the desktop you are using, or if your CD reader is internal or an external USB model.
Your thread will be temporarily locked until you provide your inxi -Faz output. You can use the edit button on your opening post to add the required information.
Our forum requires this information to be posted if you wish assistance with a technical matter. This is all spelled out in the help request template. The consequences are also spelled out if the required info is omitted, (thread locked or deleted). Please comply with the expectations of the Garuda forum if you wish to receive assistance. If you do not adhere to our forum guidlines you will need to seek assitance elsewhere.
