Snubbi
13 October 2020 06:40
1
Hi
I have never tried Conky before, but would like to use it now. I can see that there are the following packages in the archive
conky 1.11.5-4
conky-manager 2.4-4
conky-git 1.11.6.r5.g1abae952-1
conky-manager2-git 2.7-3
Which packages will you suggest. I want Conky to look like in the picture below.
Is there a good guide to setting up Conky. I have not tried Conky before.
SGS
13 October 2020 06:56
2
You need conky-lua-nv. Name is conky.orange.
The guide you find in this link
Since everyone, mostly , uses different hardware, my Conky file would not help you, especially since it requires additional files/scripts/programs.
The fun factor is huge with conky and everything you need is already on the internet.
I think I have put together everything from here many years ago so that I can't help you in particular.
\ https://github.com/brndnmtthws/conky
\ https://github.com/brndnmtthws/conky/wiki/FAQ
conky_orange_4k.lua
-- conky_orange.lua
-- author : SLK
-- version : v2011062101
-- license : Distributed under the terms of GNU GPL version 2 or later
-- modified: me
-- version : v20171027
-- notes : works on 4k screen. uses conky conf newer >v1.1
This file has been truncated. show original
conkyrc_orange_4k
conky.config = {
-- 2017/10/25
-- this is for conky version 1.1
-- converted by me using lua convert tool
-- conkyrc_orange
-- author : SLK
-- version : v2011011601
