Hello, I encountered a problem with microphone on Garuda Linux.
ISO name: garuda-dr460nized-linux-zen-210720.iso
Environment: KDE
So this might look like i'm trolling, because of the situation, trust me i'm not.
Like 3 days ago, I installed this voice changer Lyrebird, i'm not gonna lie I don't know what i exactly did, but when i tried running it asked me to install and remove a few packages so i thought its some casual file check.
I found out that pulseaudio got removed. Now cant install it. Also my microphone device isnt detected. Ill send a few screenshots in a minute. Nevermind i cant attach images xD.
Aight so heres the output.
pulseaudio pulseaudio might be found in the following packages: extra/pulseaudio 15.0-1 /usr/bin/pulseaudio
sudo pacman -S pulseaudio resolving dependencies... looking for conflicting packages... :: pulseaudio and pipewire-pulse are in conflict. Remove pipewire-pulse? [y/N] y error: failed to prepare transaction (could not statisfy dependencies) :: removing pipewire-pulse breaks dependency 'pulseaudio-bluetooth' required by gnome-bluetooth
Edit: im thinking maybe i should just reinstall garuda linux after all? I mean id lose some files, programs, but still. Mic will be necessary for me in a few weeks.
I did it via terminal sudo timeshift --restore
Chose the time, rebooted. Nothing changed at all even tho the timeshift was back at last months 27day, even the files didnt change.
(It does show that i restored tho)
That's really strange, never seen that.
Although recently I saw some posts on timeshift issues, but didn't read them in details.
Why don't you try to select that snapshot from the grub menu then confirm the restore of the same snapshot in the timeshift GUI?
Timeshift will not restore any audio
configuration files that were stored in your home directory. You could try restoring the default Garuda config using Garuda Assistant. This will reset your default configurations to the default state.
You could also try creating a new user account to see if your sound works correctly using a new account.
pulseaudio can be provided by a number of other packages.
Check your audio settings to try fix your audio problem.
Before any new post, post your system info as you should have been informed registering the forum or creating a new topic.
You need to remove pipewire-support through the garuds settings manager or garuda assistant can't remember really well open both of them and see if their is a settings tab if there is click on it and uncheck pipewire-support after doing that install pulseaudio with the Bluetooth extension.
Sorry for wasting your time, it was smthing with the drivers definetely, i tried everything that was said there. Nothing worked. So i just reinstalled the system
