Snaps installation doesn't work
cannot perform the following tasks:
  • Mount snap "snapd" (9607) ([start snap-snapd-9607.mount] failed with exit status 1: Job failed. See "journalctl -xe" for details.
how to fix?
Are you using one of the older editions or the new "Golden Eagle" release? Some older editions were reported to have problems getting snap working.
The new release seems to have helped for some people having issues. You might want to test one of the new releases if your using an older version. While reinstalling is a pain, you will get some additional benefits from reinstalling (rather than just doing regular updates).
I am using the latest version. KDE Lite
Reinstalling Pamac does nothing
