Snapper asking for authentication persist on my system
This issue has already been reported and solved in this post.
However, even though I have the involved packages up to date I keep having the authentication request on every boot:
╰─λ pacman -Qi snapper-tools
Version         : 1.1.1-2
╰─λ pacman -Qi garuda-system-maintenance
Version         : 1.6.1-1
190722-1357-Authentication Required
So far I've double checked my snapper tools configs and nothing seems to be out of place. I also went to /etc/pam.d/polkit-1 and /etc/polkit-1/rules.d/49-nopasswd-live.rules looking for suspects and got nothing. I noticed a related error:
jul 19 13:55:41 Xolotl systemd[5603]: Failed to start BTRFS Assistant Snapper check.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 122 and the job result is failed.
╰─λ journalctl -p 3 -xb
jul 19 13:55:22 Xolotl kernel:
jul 19 13:55:22 Xolotl systemd-modules-load[407]: Failed to find module 'vboxpci'
jul 19 13:55:22 Xolotl systemd-udevd[505]: event2: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
jul 19 13:55:22 Xolotl systemd-udevd[551]: host6: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb4/4-3/4->
jul 19 13:55:24 Xolotl systemd-udevd[555]: host7: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1->
jul 19 13:55:26 Xolotl kernel: Bluetooth: hci0: command 0xfc05 tx timeout
jul 19 13:55:26 Xolotl kernel: Bluetooth: hci0: Reading Intel version command failed (-110)
jul 19 13:55:40 Xolotl sddm-helper[5601]: gkr-pam: unable to locate daemon control file
jul 19 13:55:40 Xolotl systemd[5603]: /run/user/1000/systemd/generator.late/[email protected]:18: WorkingDirectory= path is not absolute, ignoring:
jul 19 13:55:40 Xolotl kded5[5820]: org.kde.plasma.dataengine.geolocation: error:  "Unknown host location.services.mozilla.com: Host not found"
jul 19 13:55:41 Xolotl kactivitymanagerd[5883]: inotify_add_watch(/home/xavigo/.local/share/recently-used.xbel) failed: (Permission denied)
jul 19 13:57:31 Xolotl sudo[9420]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:01:09 Xolotl sudo[10601]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:01:43 Xolotl sudo[10767]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:01:54 Xolotl systemd-coredump[10889]: [🡕] Process 10885 (bt-adapter) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id f3adfe4e87d3c67c20af3eeef5be985d71131c62
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module bt-adapter with build-id 8fbd0701fe633e765f66129d0a4afbf561440ab8
Stack trace of thread 10885:
#0  0x00007fa52de8536c n/a (libc.so.6 + 0x8e36c)
#1  0x00007fa52de35838 raise (libc.so.6 + 0x3e838)
#2  0x00007fa52de1f535 abort (libc.so.6 + 0x28535)
#3  0x00007fa52e24a06a n/a (libglib-2.0.so.0 + 0x1d06a)
#4  0x00007fa52e2a4ea0 g_assertion_message_expr (libglib-2.0.so.0 + 0x77ea0)
#5  0x000055d92f0db412 n/a (bt-adapter + 0x9412)
#6  0x000055d92f0d66ad n/a (bt-adapter + 0x46ad)
#7  0x00007fa52de20290 n/a (libc.so.6 + 0x29290)
#8  0x00007fa52de2034a __libc_start_main (libc.so.6 + 0x2934a)
#9  0x000055d92f0d6c3e n/a (bt-adapter + 0x4c3e)
Stack trace of thread 10887:
#0  0x00007fa52defcc3f __poll (libc.so.6 + 0x105c3f)
#1  0x00007fa52e2d7f68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2  0x00007fa52e2811cf g_main_loop_run (libglib-2.0.so.0 + 0x541cf)
#3  0x00007fa52e16aacc n/a (libgio-2.0.so.0 + 0x108acc)
#4  0x00007fa52e2b1405 n/a (libglib-2.0.so.0 + 0x84405)
#5  0x00007fa52de8354d n/a (libc.so.6 + 0x8c54d)
#6  0x00007fa52df08874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 10886:
#2  0x00007fa52e27f392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3  0x00007fa52e27f3e2 n/a (libglib-2.0.so.0 + 0x523e2)
ELF object binary architecture: AMD x86-64
░░ Subject: Process 10885 (bt-adapter) dumped core
░░ Documentation: man:core(5)
░░ Process 10885 (bt-adapter) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
jul 19 14:01:55 Xolotl sudo[11011]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:02:39 Xolotl sudo[11191]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:02:44 Xolotl sudo[11247]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:03:06 Xolotl sudo[11416]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:03:10 Xolotl sudo[11462]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:03:23 Xolotl sudo[11558]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:04:32 Xolotl systemd-coredump[11847]: [🡕] Process 11843 (bt-adapter) of user 1000 dumped core.
Stack trace of thread 11843:
#0  0x00007f194eba836c n/a (libc.so.6 + 0x8e36c)
#1  0x00007f194eb58838 raise (libc.so.6 + 0x3e838)
#2  0x00007f194eb42535 abort (libc.so.6 + 0x28535)
#3  0x00007f194ef6d06a n/a (libglib-2.0.so.0 + 0x1d06a)
#4  0x00007f194efc7ea0 g_assertion_message_expr (libglib-2.0.so.0 + 0x77ea0)
#5  0x0000555b042b8412 n/a (bt-adapter + 0x9412)
#6  0x0000555b042b36ad n/a (bt-adapter + 0x46ad)
#7  0x00007f194eb43290 n/a (libc.so.6 + 0x29290)
#8  0x00007f194eb4334a __libc_start_main (libc.so.6 + 0x2934a)
#9  0x0000555b042b3c3e n/a (bt-adapter + 0x4c3e)
Stack trace of thread 11844:
#0  0x00007f194ec1fc3f __poll (libc.so.6 + 0x105c3f)
#1  0x00007f194effaf68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2  0x00007f194efa2392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3  0x00007f194efa23e2 n/a (libglib-2.0.so.0 + 0x523e2)
#4  0x00007f194efd4405 n/a (libglib-2.0.so.0 + 0x84405)
#5  0x00007f194eba654d n/a (libc.so.6 + 0x8c54d)
#6  0x00007f194ec2b874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 11845:
#2  0x00007f194efa41cf g_main_loop_run (libglib-2.0.so.0 + 0x541cf)
#3  0x00007f194ee8dacc n/a (libgio-2.0.so.0 + 0x108acc)
░░ Subject: Process 11843 (bt-adapter) dumped core
░░ Process 11843 (bt-adapter) crashed and dumped core.
jul 19 14:04:33 Xolotl sudo[11961]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:04:38 Xolotl sudo[12087]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:05:09 Xolotl systemd-coredump[12171]: [🡕] Process 12167 (bt-adapter) of user 1000 dumped core.
Stack trace of thread 12167:
#0  0x00007f21a989f36c n/a (libc.so.6 + 0x8e36c)
#1  0x00007f21a984f838 raise (libc.so.6 + 0x3e838)
#2  0x00007f21a9839535 abort (libc.so.6 + 0x28535)
#3  0x00007f21a9c6406a n/a (libglib-2.0.so.0 + 0x1d06a)
#4  0x00007f21a9cbeea0 g_assertion_message_expr (libglib-2.0.so.0 + 0x77ea0)
#5  0x00005580485aa412 n/a (bt-adapter + 0x9412)
#6  0x00005580485a56ad n/a (bt-adapter + 0x46ad)
#7  0x00007f21a983a290 n/a (libc.so.6 + 0x29290)
#8  0x00007f21a983a34a __libc_start_main (libc.so.6 + 0x2934a)
#9  0x00005580485a5c3e n/a (bt-adapter + 0x4c3e)
Stack trace of thread 12168:
#0  0x00007f21a9916c3f __poll (libc.so.6 + 0x105c3f)
#1  0x00007f21a9cf1f68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2  0x00007f21a9c99392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3  0x00007f21a9c993e2 n/a (libglib-2.0.so.0 + 0x523e2)
#4  0x00007f21a9ccb405 n/a (libglib-2.0.so.0 + 0x84405)
#5  0x00007f21a989d54d n/a (libc.so.6 + 0x8c54d)
#6  0x00007f21a9922874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 12169:
#2  0x00007f21a9c9b1cf g_main_loop_run (libglib-2.0.so.0 + 0x541cf)
#3  0x00007f21a9b84acc n/a (libgio-2.0.so.0 + 0x108acc)
░░ Subject: Process 12167 (bt-adapter) dumped core
░░ Process 12167 (bt-adapter) crashed and dumped core.
jul 19 14:05:09 Xolotl sudo[12282]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:08:38 Xolotl sudo[12807]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:09:23 Xolotl sudo[12961]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:12:49 Xolotl sudo[13117]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:13:31 Xolotl sudo[13186]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
jul 19 14:13:59 Xolotl sudo[13266]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
My garuda-inxi for reference:
Kernel: 5.18.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=543c6354-5d39-4703-bb64-407600dc772d rw [email protected]
resume=UUID=65b1555e-e8e7-41cb-84a2-63265cdbd7db loglevel=3 ibt=off
threadirqs
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Mobo: ASUSTeK model: TUF GAMING B550M-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3597 high: 3606 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3601
3: 3595 4: 3596 5: 3598 6: 3597 7: 3596 8: 3591 9: 3598 10: 3606 11: 3591
12: 3598 bogomips: 88793
STIBP: always-on, RSB filling
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 07:00.0
chip-ID: 10de:1d01 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 515.57
direct render: Yes
Device-1: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-1:2 pcie: chip-ID: 0499:1509
class-ID: ff00 gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 07:00.1
chip-ID: 10de:0fb8 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha Steinberg UR22 type: USB driver: snd-usb-audio
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.18.12-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
bus-ID: 1-5:2 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 1.14 TiB used: 847.86 GiB (72.8%)
model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
rev: 111110WD temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1053 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 16.18 GiB (16.2%)
ID-3: /home raw-size: 128.59 GiB size: 128.59 GiB (100.00%)
used: 80.89 GiB (62.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 16.18 GiB (16.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.53 GiB used: 516.5 MiB (3.2%)
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 36.5 C mobo: 35.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): fan-1: 1018 fan-2: 1294 fan-3: 1041 fan-7: 0
Processes: 443 Uptime: 9m wakeups: 6 Memory: 15.54 GiB
used: 3.96 GiB (25.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1675
lib: 363 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.19
Garuda (2.6.5-1):
System install date:     2021-08-04
Last full system update: 2022-07-19
