I just installed Garuda Linux Gaming Edition because I wanted to try out Linux and a friend recommended me it, but the issues that I have been having are really annoying. One of the issues I have is whenever I try and run steam I keep getting this error saying "Fatal Error: Steam needs to be online to update. Please confirm your network connection and try again." I have searched these forums and other forums and nothing worked. The other issues is that I have been trying to use Snap and when I try and install the Snap Store, I get this error "Error: cannot perform the following tasks: -Run Configure hook of "Snap-store" snap if present (run hook "configure": cannot locate base snap core18 no such file or directory", I have Core 18 installed, the other issue i have been having is that I installed Spotify through Snap, and I got this notification whenever I try and open it saying "Launching Spotify Failed. Chdir: No such file or directory".
I will admit I have been enjoying linux so far but it's really annoying having these issues with it, i don't know if it is that I am fairly new so I am making some mistakes in installing/running things but if anyone can help that would be great. Thank you!.
