SN30 Pro 2 not working when connected via bluetooth
I connected an 8bitdo SN30 Pro 2 to my laptop wirelessly and opened up steam, after I opened up the controller settings, It didn't show up, I then installed xpad and rebooted, but it didn't work. I've tried every mode on the controller and none of them work. When I connect it with the cable , it seems to work perfectly, anyone know what's wrong?
  Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=4099c804-740b-4c2b-be89-691b4c6c569a rw [email protected]
    resume=UUID=7a2bef2e-2051-49ea-b2c2-476cfbd79f28 loglevel=3
    sdhci.debug_quirks2=4 ibt=off acpi_backlight=native
  Desktop: dwm v: 6.3 vt: 1 dm: LightDM v: 1.32.0 Distro: Garuda Linux
  Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0
    serial: <superuser required> Chassis: type: 10 v: Mac-6F01561E16C75D06
  Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2
    serial: <superuser required> UEFI: Apple v: 425.0.0.0.0 date: 10/26/2021
  ID-1: BAT0 charge: 36.8 Wh (76.8%) condition: 47.9/62.9 Wh (76.2%)
    volts: 12.4 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
    status: charging cycles: 443
  Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2893 min/max: 1200/3100 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 2893 2: 2893 3: 2893 4: 2893 bogomips: 19954
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
    active: HDMI-A-1 off: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-2, HDMI-A-3,
    VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
    bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
  Display: server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8 driver: X:
    loaded: intel dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x284mm (19.92x11.18")
    s-diag: 580mm (22.84")
  Monitor-1: HDMI-A-1 mapped: HDMI1 pos: primary model: Samsung
    serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
    size: 700x390mm (27.56x15.35") diag: 801mm (31.5") ratio: 16:9 modes:
  Monitor-2: LVDS-1 mapped: LVDS1 note: disabled model: Apple 0x9cc5
    built: 2009 res: 1920x1080 dpi: 114 gamma: 1.2 size: 286x179mm (11.26x7.05")
    diag: 337mm (13.3") ratio: 16:10 modes: 1280x800
  API: OpenGL v: 4.2 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) direct-render: Yes
  Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-2: PulseAudio v: 16.1 running: yes
  Sound Server-3: PipeWire v: 0.3.67 running: yes
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
    bus-ID: 02:00.0 chip-ID: 14e4:4331 class-ID: 0280
  Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
    bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
  Local Storage: total: 931.51 GiB used: 526.09 GiB (56.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    type: SSD serial: <filter> rev: 033 temp: 37 C scheme: GPT
  ID-1: / raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
    used: 524.94 GiB (56.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 70.7 MiB (23.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
  ID-4: /var/log raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
  ID-5: /var/tmp raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
  ID-1: swap-1 type: zram size: 3.73 GiB used: 3.73 GiB (100.0%)
  ID-2: swap-2 type: partition size: 8.23 GiB used: 1.08 GiB (13.2%)
  System Temperatures: cpu: 71.0 C mobo: N/A
  Processes: 271 Uptime: 1h 3m wakeups: 41 Memory: 3.74 GiB
  used: 2.09 GiB (56.0%) Init: systemd v: 253 default: multi-user
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 3452 pm: dpkg
  pkgs: 0 pm: pacman pkgs: 3429 libs: 678
  tools: gnome-software,octopi,pamac,paru,trizen,yay pm: flatpak pkgs: 23
  Shell: fish v: 3.6.0 running-in: alacritty inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2022-04-24
  Last full system update: 2023-03-21 ↻
  Failed units:            anbox-container-manager.service systemd-networkd-wait-online.service
