Smokys inxi -Fxxxza
System:    Kernel: 5.16.5-2-cacule-rdb-lto x86_64 bits: 64 compiler: clang v: 13.0.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule-rdb-lto
root=UUID=8e50e065-11b1-4774-8082-1ab1ea33981e rw [email protected] splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
usbhid.poll=1 sysrq_always_enabled=1
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine:   Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2423 date: 08/10/2021
CPU:       Info: 12-Core model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L1: 768 KiB L2: 6 MiB
L3: 64 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 192215
Speed: 4000 MHz min/max: 2200/4000 MHz base/boost: 4000/4650 boost: enabled volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 4000 2: 4000 3: 3998 4: 3999 5: 4000 6: 4000 7: 4000
8: 4000 9: 4000 10: 3999 11: 3999 12: 4000 13: 4000 14: 4000 15: 4000 16: 4000 17: 4001
18: 4000 19: 4000 20: 4000 21: 4000 22: 4000 23: 4000 24: 4000
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics:  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-9:8
chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver: loaded: amdgpu display-ID: :0
Screen-1: 0 s-res: 3840x2160 s-dpi: 192 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: DisplayPort-0 res: 3840x2160 hz: 60 dpi: 154 size: 632x360mm (24.9x14.2")
diag: 727mm (28.6")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.44.0 5.16.5-2-cacule-rdb-lto LLVM 13.0.1)
v: 4.6 Mesa 21.3.5 direct render: Yes
Audio:     Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Device-3: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-9:8
Sound Server-1: ALSA v: k5.16.5-2-cacule-rdb-lto running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Network:   Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel port: N/A bus-ID: 07:00.0
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Drives:    Local Storage: total: 6.15 TiB used: 3.81 TiB (62.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Corsair MP400 size: 1.82 TiB
rev: ECFM53.0 temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 243d 12h cycles: 902 read-units: 178,556,853 [91.4 TB]
written-units: 284,825,010 [145 TB]
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
SMART: yes health: PASSED on: 119d 5h cycles: 898 read-units: 11,073,089 [5.66 TB]
written-units: 11,250,620 [5.76 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1 family: Micron Client SSDs
size: 931.51 GiB block-size: physical: 512 B logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 020 temp: 43 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 33d 8h cycles: 830 written: 6.23 TiB Old-Age:
UDMA CRC errors: 10750 alert: Bad cable/connection?
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 2TB size: 1.82 TiB block-size:
physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q
temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 96d 3h cycles: 1893 written: 29.4 TiB
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB family: based SSDs
size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 2B6Q temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 161d 3h cycles: 3865 written: 31.86 TiB
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Samsung model: Type-C size: 239.02 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1100 scheme: GPT
Partition: ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 979.93 GiB (52.7%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 599 MiB size: 597.8 MiB (99.80%) used: 259.9 MiB (43.5%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 979.93 GiB (52.7%) fs: btrfs
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 979.93 GiB (52.7%) fs: btrfs
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 979.93 GiB (52.7%) fs: btrfs
ID-1: swap-1 type: zram size: 62.78 GiB used: 3.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 48.5 C mobo: 37.0 C gpu: amdgpu temp: 57.0 C mem: 60.0 C
Fan Speeds (RPM): fan-1: 981 fan-2: 1430 fan-3: 751 fan-4: 920 fan-5: 0 fan-6: 0 fan-7: 0
gpu: amdgpu fan: 0
Info:      Processes: 499 Uptime: 7m wakeups: 0 Memory: 62.78 GiB used: 8.99 GiB (14.3%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.2.1 clang: 13.0.1 Packages: pacman: 2432 lib: 595
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.07
Garuda (2.5.4-2):
System install date:     2021-05-07
Last full system update: 2022-02-04
Windows dual boot:       Yes
:exploding_head:
System:    Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=56bb78b7-6a47-43f7-80ec-23c4a93622ff
rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 3402 date: 03/22/2021
CPU:       Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 182056
Speed: 3043 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 3219 2: 3332
3: 3593 4: 3594 5: 3067 6: 3068 7: 4490 8: 3593 9: 3591 10: 3592 11: 4067 12: 3577 13: 4505
14: 3574 15: 3586 16: 3632 17: 3552 18: 3593 19: 3594 20: 3593 21: 3997 22: 3493 23: 3601
24: 3587
Graphics:  Device-1: NVIDIA GA102 [GeForce RTX 3080] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:2206 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
note: n/a (using device driver) unloaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 144 s-size: 1355x381mm (53.3x15.0") s-diag: 1408mm (55.4")
Monitor-1: DP-0 res: 3840x2160 hz: 60
Monitor-2: DP-2 res: 3840x2160 hz: 60 dpi: 161 size: 607x345mm (23.9x13.6") diag: 698mm (27.5")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio:     Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-2: Astro Gaming A50 type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.4:6
chip-ID: 9886:0015 class-ID: 0300
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Network:   Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: d000
bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
Drives:    Local Storage: total: 5.46 TiB used: 411.23 GiB (7.4%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 960 EVO 1TB size: 931.51 GiB
rev: 3B7QCXE7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
rev: 2B2QEXM7 temp: 43.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000LM024-2AN17V size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5526
serial: <filter> rev: 0001 scheme: MBR
Partition: ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 411.23 GiB (44.2%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 411.23 GiB (44.2%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 411.23 GiB (44.2%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 411.23 GiB (44.2%)
ID-1: swap-1 type: zram size: 15.59 GiB used: 1.43 GiB (9.2%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): fan-2: 1486 fan-3: 1532 fan-4: 967 fan-5: 1505 fan-6: 1205 gpu: nvidia
fan: 30%
Info:      Processes: 427 Uptime: 8h 18m wakeups: 0 Memory: 15.59 GiB used: 3.99 GiB (25.6%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1904 lib: 515
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
