SkyShowtime - not work :(
Hi,
is there any chance to fix it? is the problem only with skyshowtime?
Unfortunately, the system is not compatible with SkyShowtime. Check out a simple device in our Help Center (6007).
There are a lot of hits at a simple internet search saying that Linux is not supported. E.g.
https://www.reddit.com/r/SkyShowtime/comments/14zeh24/why_is_skyshowtime_still_not_supported_on_linux/
This is just a random pick, but it seems a matter of fact...
ok, thx
I just wanted to ask but have you already tried wine? Infact I have used some windows software on steam (not just games) using proton by loading them as non-native games on steam and forcing them to use proton-6.8 to work.
Or you could also just spin a windows vm and install this app inside that vm.
