Shutdown process hangs
Hello, when I wanted to shut down the laptop it got stuck on the following picture. Journalctl -p err returned the following information.
Apr 02 17:59:38 susanne-20hr002mge nmbd[1178]: [2024/04/02 17:59:38.528894,  0] ../../source3/nmbd/nmbd_nameq>
Apr 02 17:59:38 susanne-20hr002mge nmbd[1178]:   query_name_response: Multiple (2) responses received for a q>
Apr 02 17:59:38 susanne-20hr002mge nmbd[1178]:   This response was from IP 192.168.178.20, reporting an IP ad>
Apr 02 17:59:38 susanne-20hr002mge nmbd[1178]: [2024/04/02 17:59:38.528998,  0] ../../source3/nmbd/nmbd_nameq>
Apr 02 17:59:38 susanne-20hr002mge nmbd[1178]:   query_name_response: Multiple (3) responses received for a q>
Apr 02 17:59:38 susanne-20hr002mge nmbd[1178]:   This response was from IP 192.168.178.21, reporting an IP ad>
Apr 02 18:04:52 susanne-20hr002mge nmbd[1178]: [2024/04/02 18:04:52.133252,  0] ../../source3/nmbd/nmbd_nameq>
Apr 02 18:04:52 susanne-20hr002mge nmbd[1178]:   query_name_response: Multiple (2) responses received for a q>
Apr 02 18:04:52 susanne-20hr002mge nmbd[1178]:   This response was from IP 192.168.178.20, reporting an IP ad>
Apr 02 18:04:52 susanne-20hr002mge nmbd[1178]: [2024/04/02 18:04:52.133342,  0] ../../source3/nmbd/nmbd_nameq>
Apr 02 18:04:52 susanne-20hr002mge nmbd[1178]:   query_name_response: Multiple (3) responses received for a q>
Apr 02 18:04:52 susanne-20hr002mge nmbd[1178]:   This response was from IP 192.168.178.21, reporting an IP ad>
Apr 02 18:09:08 susanne-20hr002mge dbus-broker-launch[534]: Activation request for 'org.freedesktop.Avahi' fa>
Apr 02 18:09:08 susanne-20hr002mge dbus-broker-launch[534]: Activation request for 'org.bluez' failed.
Apr 02 18:09:08 susanne-20hr002mge dbus-broker-launch[534]: Activation request for 'org.freedesktop.nm_dispat>
Apr 02 18:09:09 susanne-20hr002mge dbus-broker-launch[534]: Activation request for 'org.freedesktop.nm_dispat>
-- Boot f569e72e17064c908950405d231a6e2d --
Apr 02 18:31:29 susanne-20hr002mge kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Apr 02 18:31:30 susanne-20hr002mge kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
Apr 02 18:31:31 susanne-20hr002mge kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
lines 1-27
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0ed49918-7420-48a6-932a-26fef437d125 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: LENOVO product: 20HR002MGE v: ThinkPad X1 Carbon 5th
Mobo: LENOVO model: 20HR002MGE v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20HR_BU_Think_FM_ThinkPad
X1 Carbon 5th uuid: <superuser required> UEFI: LENOVO v: N1MET73W (1.58 )
date: 04/04/2023
ID-1: BAT0 charge: 31.9 Wh (80.6%) condition: 39.6/57.0 Wh (69.4%)
power: 21.1 W volts: 12.9 min: 11.6 model: LGC 01AV429 type: Li-poly
serial: <filter> status: charging cycles: 378
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 800 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 23199
Device-1: Intel HD Graphics 620 vendor: Lenovo ThinkPad X1 Carbon 5th Gen
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b5ce
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x313d built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 15.02 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 24.0.4-arch1.2
device-ID: 8086:5916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.4-arch1.2 (LLVM
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad X1 Carbon
5th Gen driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad X1 Carbon 5th Gen
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
IF-ID-1: wwp0s20f0u6i12 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 74.89 GiB (15.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 51055KLA temp: 36.9 C
used: 74.89 GiB (15.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.38 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.38 GiB used: 3.06 GiB (19.9%)
Processes: 219 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1533 libs: 429 tools: pamac,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-04-01
Last full system update: 2024-04-03
That doesn’t help, but you’re not alone:
I quickly see 3 commonalities with potential:
And like in the other thread, my initial troubleshooting step is always: try with a different kernel, starting with linux-lts (and headers)
Maybe also check this (e.g. try disabling bluetooth):
https://bbs.archlinux.org/viewtopic.php?pid=2161144
And relevant links therein.
First of all, thank you for your feedback. I didn’t have Bluetooth turned on. I switched to the LTS kernel but when I shut down the laptop it still hangs.
The “funny” thing is that it also changes the DHCP setting in the BIOS, so WOL no longer works. Only
sudo poweroff
works for me.
It is also strange that on a multiboot computer it only happens with KDE and Hyprland and not with i3wm.
Thanks for the link filo :slight_smile:
