When I tried to shutdown Dr460nized, it was frozen at the garuda logo...
Need help...
Might try ESC for a view of what's happening (or not happening). Not an expert on this, but I have seen stop jobs hang on, and knowing which often leads to the problem...
I tried ESC, but nothing happened...
Stuck on the logo and everything stops - laptop fan, mouse led, and I think keyboard also stop, that's why ESC not working...
I never use ESC at shutdown but how you do the shutdown process?
Button/software button and where?
And try from terminal with
systemctl poweroff -i
When I stuck, I just long press power button to shutdown directly...
I tried the command and stuck on logo like before...
Try next time Ctrl + Alt + F3
and same in post above after you login .
Maybe btrfs cleaner and more is in Progress at shutdown.
Sometimes I must wait long time (3 min.) until PC is off.
You can break your system with hard reset with button.
Ok...
Ctrl + Alt + F3
Then shutdown command...
Now stuck again and waiting for complete shutdown
Lets see...
5 min and still stuck...
I think I have to install it again....
Maybe some file or config is corrupted
Is your system upto date ?
There was a bug in kernel older than 5.9.12
It was kernel panic on shutdown
Please make sure you have updated your system
Yes i run sudo pacman -Syu 4-5 times a day...my system is updated..
Running kernel - linux-tkg-bmq 5.9.13-98
please post output…
Not in tty !
Do you have usb connected ?
Its possible somethings arent able to unmount
Be fore shutting down make sure to disconnect all peripheral devices connected
cat /etc/fstab
Also you can try changing kernel
Try linux kernel
sudo pacman -Syu linux linux-headers
There is no output...
When I enter the command it starts shutdown the system...
1 - Usb Mouse
2 - NTFS drives mounted (maybe this one causing the error)
cat /etc/fstab 100% ─╯
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=5F94-3518 /boot/efi vfat umask=0077 0 2
UUID=005202c8-da43-43f2-a348-32e5e02c938a swap swap defaults,noatime 0 0
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a / btrfs subvol=@,defaults,noatime,space_cache,autodefrag,compress=zstd 0 1
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a /home btrfs subvol=@home,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a /root btrfs subvol=@root,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a /srv btrfs subvol=@srv,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a /var/cache btrfs subvol=@cache,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a /var/log btrfs subvol=@log,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=bff6cfd4-4d98-47c2-993c-2732cc71340a /var/tmp btrfs subvol=@tmp,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
It shut down normal?
Or same error?
normal shutdown...no error occoured
