Shutdown glitch
Hi​:wave:
I am using Garuda Mate and i am getting an issue.
My pc take around 30 seconds for shutting down after pressing the shutdown button.. looks like freezing.
Please provide your:
As required by the topic template.
Maybe include also an abstract of the journal at the time of the last shutdown.
Format the text like this
text
I have my a little old garuda inxi command output.
Here it is,
    root=UUID=a07da2a9-0e78-41ad-9fea-d9403d0b7047 rw rootflags=subvol=@
    resume=UUID=ec83f55d-694c-4175-a51c-0254db737104 loglevel=3 ibt=off
  Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
    UEFI: American Megatrends v: 4.6.5 date: 05/29/2019
  Info: model: Intel Core i3-3220 bits: 64 type: MT MCP arch: Ivy Bridge
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1598 high: 1600 min/max: 1600/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1597
    4: 1597 bogomips: 26338
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915
    active: VGA-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:0152 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: marco v: 1.26.1 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
    s-diag: 414mm (16.31")
  Monitor-1: VGA-1 model: EW32S3PW serial: <filter> built: 2012
    res: 1366x768 hz: 60 dpi: 30 gamma: 1.2 size: 1150x650mm (45.28x25.59")
    diag: 1321mm (52") ratio: 16:9 modes: max: 1366x768 min: 720x400
    missing.
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
  Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
    bus-ID: 2-1.5:5 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
  IF: wlp0s29u1u5 state: up mac: <filter>
  Local Storage: total: 599.6 GiB used: 16.07 GiB (2.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
    type: HDD rpm: 7200 serial: <filter> rev: KC48 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 model: SATA SSD 128GB size: 119.24 GiB
    block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
    serial: <filter> rev: 537 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Blade
    size: 14.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
  ID-1: / raw-size: 40 GiB size: 40 GiB (100.00%) used: 3.97 GiB (9.9%)
    fs: btrfs dev: /dev/sdb3 maj-min: 8:19
    used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 304.1 GiB size: 304.1 GiB (100.00%)
    used: 50.3 MiB (0.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-4: /var/log raw-size: 40 GiB size: 40 GiB (100.00%)
    used: 3.97 GiB (9.9%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
  ID-5: /var/tmp raw-size: 40 GiB size: 40 GiB (100.00%)
  ID-1: swap-1 type: zram size: 6.72 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb2 maj-min: 8:18
  System Temperatures: cpu: 39.0 C mobo: N/A
  Processes: 226 Uptime: 18m wakeups: 0 Memory: 6.73 GiB
  used: 2.01 GiB (29.9%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1174
  libs: 347 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: mate-terminal
  inxi: 3.3.26
  System install date:     2023-07-17
  Last full system update: 2023-07-17
This is not necessarily the root cause of your issue, but you should really update, otherwise it will get more challenging in the future.
garuda-update
I had updated this.. but still its taking time..
No message?
Are there still programs open that the system closes?
Are external drives/sticks connected?
It’s a bug of mine, but please check if there is an update for your 2019 BIOS.
It’s just to check it off the list. Also, have you tried any other kernels yet?
And, finally, please post the output of the following command (use sudo):
# systemd-analyze blame
‘#’ indicates a root superuser command
How to update bios?
Start with answer the questions, please.
Post output from.
journalctl -b -1 -r
Now its working properly after running these commands again.
sudo pacman -Sy
sudo pacman -Syu
The second includes the first one, and both are covered by the garuda-update alrady executed earlier.
So, the solution remains a mystery, but all good...!
Lol. Idk how i fixed this maybe some glitch or something
forum helpers gotta go check their necks for puncture wounds now >.>
No need, my white shirt has blood red stains on the neck. :grin:
I mark the solution.
Well, at least when (not if) they screw the pooch again, at least now they have a few troubleshooting tips in their box o' tools.
:wink:
