Shutdown and restart buttons went missing
Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=009286cb-0285-4127-a549-89672838992b rw rootflags=subvol=@
quiet resume=UUID=58b306a5-086f-46bd-affd-6a1e60fb5244 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1654 date: 08/25/2023
Device-1: nintendo_switch_controller_battery_0003:057E:2009.0008 model: N/A
serial: N/A charge: Full status: full
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2552 high: 4794 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4358 2: 3847 3: 4699
4: 400 5: 4794 6: 400 7: 400 8: 3550 9: 400 10: 3906 11: 3311 12: 3200
13: 400 14: 400 15: 3202 16: 3573 bogomips: 144003
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3 off: HDMI-A-1 empty: DP-1,DP-2,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
LLVM 17.0.6 DRM 3.57 6.9.5-zen1-1-zen) device-ID: 1002:73bf
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 6.84 TiB used: 1.79 TiB (26.2%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Addlink
model: M.2 PCIE G3x4 NVMe RGB size: 953.87 GiB block-size: physical: 512 B
fw-rev: ECFM12.3 temp: 25.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM001-1CH166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB
ID-1: / raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
used: 262.66 GiB (29.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
ID-4: /var/log raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.02 GiB size: 897.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 26 MiB (0.1%) priority: 100
ID-2: swap-2 type: partition size: 34.19 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 43.9 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 58.0 C
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 6.4 GiB (20.6%)
Processes: 402 Power: uptime: 1h 41m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 2112 libs: 593 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2024-03-21
Last full system update: 2024-06-20
The “shutdown” and “restart” buttons are gone
Keep an eye on this still open KDE bug report.
https://bugs.kde.org/show_bug.cgi?id=488187
I think that might be something unrelated. This looks like it is intentional part of KDE 6.1
Under “Streamlining User Experience” :
Looks like you will only get options to what the prior button you were using (in this case, logging out)
Using the shutdown button (down below on the Application Launcher) should show only shutdown now with KDE 6.1 as well.
edit: found this 488832 – Add a button/option that will show the logout screen with all options
It’s a feature, not a bug. Don’t kill the messenger though, I don’t like it either.
swap the widget out for SCP menu an put it over there (configure it as well) The button you click is the prompt that will pop up as said above its a feature not a bug
There has been work going on to fix this:
" With the change to simplify the logout greeter UI when invoked with a specific option, there is currently no option to trigger the logout greeter with all of the options via any existing actions.
This adds a Leave action which shows the logout greeter with available options."
EDIT: The fix has been merged and will be available in KDE 6.2
There’s already a way that might be useful for many to add a Leave option in the right-click context menu.
