Hi all
Just started with this distro and I'm liking it. My main issue is that reboot and shutdown take about 90 seconds when done via the gui and the 'shutdown now' command. 'Poweroff -f' and 'reboot -f' commands are near instantaneous.
Any ideas?
System: Kernel: 5.10.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=bdfc4503-f56a-4697-92ba-5f399022df77 rw
rootflags=subvol=@ splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
loglevel=3 systemd.log_level=debug systemd.log_target=kmsg log_buf_len=1M printk.devkmsg=on enforcing=0
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.51 date: 11/13/2020
CPU: Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25) model-id: 21 (33)
stepping: N/A microcode: A201009 L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 121612
Speed: 3594 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 3594 2: 3590 3: 3595 4: 3593 5: 3596
6: 3588 7: 3601 8: 3596 9: 3636 10: 3577 11: 3600 12: 3585 13: 3622 14: 3602 15: 3587 16: 3606
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Tonga PRO [Radeon R9 285/380] vendor: PC Partner Limited driver: amdgpu
v: kernel bus ID: 2b:00.0 chip ID: 1002:6939 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0") s-diag: 987mm (38.8")
Monitor-1: DisplayPort-0 res: 3440x1440 dpi: 110 size: 797x334mm (31.4x13.1") diag: 864mm (34")
OpenGL: renderer: AMD Radeon R9 380 Series (TONGA DRM 3.40.0 5.10.16-zen1-1-zen LLVM 11.0.1) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Tonga HDMI Audio [Radeon R9 285/380] vendor: PC Partner Limited
driver: snd_hda_intel v: kernel bus ID: 2b:00.1 chip ID: 1002:aad8 class ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 2d:00.4 chip ID: 1022:1487 class ID: 0403
Device-3: Focusrite-Novation Scarlett 2i4 type: USB driver: snd-usb-audio bus ID: 1-4.1:4 chip ID: 1235:800a
class ID: fe01
Device-4: JMTek LLC. KLIM Impact type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-4.2:6
chip ID: 0c76:1466 class ID: 0300
Device-5: Sunplus Innovation SPCA2281 Web Camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-4.4:9
chip ID: 1bcf:2281 class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.10.16-zen1-1-zen
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel bus ID: 29:00.0
chip ID: 8086:24fb class ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus ID: 2a:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp42s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-9:7 chip ID: 8087:0aa7
class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 1.39 TiB used: 33.03 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP size: 953.87 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 32B3T8EA temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0A-00SM50 size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 00WD scheme: GPT
Partition: ID-1: / raw size: 149.41 GiB size: 149.41 GiB (100.00%) used: 21.79 GiB (14.6%) fs: btrfs dev: /dev/nvme0n1p4
maj-min: 259:4
ID-2: /boot/efi raw size: 1000 MiB size: 996 MiB (99.60%) used: 25.8 MiB (2.6%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 465.76 GiB size: 465.76 GiB (100.00%) used: 11.22 GiB (2.4%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/log raw size: 149.41 GiB size: 149.41 GiB (100.00%) used: 21.79 GiB (14.6%) fs: btrfs
ID-5: /var/tmp raw size: 149.41 GiB size: 149.41 GiB (100.00%) used: 21.79 GiB (14.6%) fs: btrfs
ID-1: swap-1 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 620
Info: Processes: 385 Uptime: 6m wakeups: 0 Memory: 31.34 GiB used: 4.1 GiB (13.1%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: 1619 pacman: 1615 lib: 468 flatpak: 4 Shell: fish v: 3.1.2 running in: yakuake
inxi: 3.3.01
Thanks!
SGS
18 February 2021 09:31
2
Read
How to search for solutions the right way
please
and post
systemd-analyze blame
systemd-analyze
and
6.446s NetworkManager-wait-online.service
2.446s systemd-swap.service
1.710s upower.service
228ms lvm2-monitor.service
191ms systemd-tmpfiles-setup.service
150ms systemd-random-seed.service
146ms udisks2.service
122ms dev-nvme0n1p4.device
119ms [email protected]
115ms [email protected]
83ms ananicy.service
49ms systemd-journal-flush.service
44ms systemd-logind.service
41ms systemd-udevd.service
37ms systemd-journald.service
35ms systemd-udev-trigger.service
33ms systemd-fsck@dev-disk-by\x2duuid-0CDE\x2d8B9A.service
32ms polkit.service
30ms systemd-modules-load.service
29ms smb.service
29ms ModemManager.service
28ms NetworkManager.service
25ms systemd-timesyncd.service
21ms avahi-daemon.service
21ms plymouth-deactivate.service
20ms plymouth-quit-wait.service
20ms plymouth-quit.service
20ms dev-zram3.swap
20ms dev-zram15.swap
18ms dev-zram9.swap
17ms systemd-guest-user.service
17ms dev-zram7.swap
17ms dev-zram5.swap
17ms dev-zram13.swap
16ms dev-zram4.swap
16ms systemd-vconsole-setup.service
15ms nmb.service
15ms dev-zram8.swap
15ms dev-zram2.swap
14ms thermald.service
14ms plymouth-start.service
14ms dev-zram0.swap
13ms dev-zram1.swap
12ms dev-zram11.swap
12ms dev-zram10.swap
12ms systemd-fsck@dev-disk-by\x2duuid-349b82ed\x2d0084\x2d42ae\x2d8b70\x2d8b1b54fc68be.service
11ms dev-zram14.swap
11ms dev-zram12.swap
11ms plymouth-read-write.service
10ms systemd-sysctl.service
10ms home.mount
9ms systemd-guest-config.service
9ms dev-zram6.swap
8ms systemd-remount-fs.service
8ms cups.service
8ms boot-efi.mount
7ms systemd-tmpfiles-clean.service
6ms keychron.service
6ms [email protected]
5ms colord.service
5ms bluetooth.service
5ms dev-hugepages.mount
5ms dev-mqueue.mount
5ms systemd-tmpfiles-setup-dev.service
4ms sys-kernel-debug.mount
4ms systemd-binfmt.service
4ms sys-kernel-tracing.mount
4ms tmp.mount
4ms kmod-static-nodes.service
3ms [email protected]
3ms systemd-fsck@dev-disk-by\x2duuid-bdfc4503\x2df56a\x2d4697\x2d92ba\x2d5f399022df77.service
3ms systemd-user-sessions.service
2ms systemd-update-utmp.service
2ms root.mount
2ms rtkit-daemon.service
2ms srv.mount
2ms var-cache.mount
2ms wpa_supplicant.service
2ms var-log.mount
1ms systemd-rfkill.service
1ms var-tmp.mount
1ms home-guest.mount
1ms proc-sys-fs-binfmt_misc.mount
990us sys-kernel-config.mount
632us sys-fs-fuse-connections.mount
Startup finished in 20.661s (firmware) + 6.336s (loader) + 2.302s (kernel) + 7.198s (userspace) = 36.499s
graphical.target reached after 7.198s in userspace
SGS
18 February 2021 09:36
4
Check your /etc/fstab for wrong UUID or missing harware:
sudo blkid | grep sd
/dev/nvme0n1p1: UUID="0CDE-8B9A" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="ff10d880-affd-43d0-b996-7dd396d2191e"
/dev/nvme0n1p3: BLOCK_SIZE="512" UUID="E058DC4F58DC2656" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="1e5dc3de-b083-4e7f-912e-4e49f6997e9c"
/dev/nvme0n1p4: UUID="bdfc4503-f56a-4697-92ba-5f399022df77" UUID_SUB="da670ce5-b093-4b73-a272-951cb9b29d5e" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="a23ee579-7ed1-4442-a8a9-e05df7d29895"
/dev/sda1: UUID="349b82ed-0084-42ae-8b70-8b1b54fc68be" UUID_SUB="a429af80-ad3c-414f-90f7-5640c7e41d50" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="3d6beaf9-7658-b842-99b5-75cdaf04f6c4"
/dev/zram0: UUID="09fca2fa-9ae4-4a37-96ef-3067b1654b32" TYPE="swap"
/dev/zram1: UUID="7099c716-6d41-4ebf-bb3d-ae3947979d25" TYPE="swap"
/dev/zram2: UUID="bc22a708-14c2-43e0-ae13-a6a998040ed5" TYPE="swap"
/dev/zram3: UUID="338bf3f9-0c1c-48b4-b8c5-d56f6ebed832" TYPE="swap"
/dev/zram4: UUID="17e23327-8eaf-4566-87ba-9677066dba63" TYPE="swap"
/dev/zram5: UUID="a3c8fc9c-0dc0-4e2d-aaea-666055265efc" TYPE="swap"
/dev/zram6: UUID="c4f228ee-951a-4e21-8bdd-490f64608b1e" TYPE="swap"
/dev/zram7: UUID="3ed03f67-bd36-4997-96f1-0e992e664e29" TYPE="swap"
/dev/zram8: UUID="31ef1dd6-6c23-46b7-9983-0d48e1cd4a34" TYPE="swap"
/dev/zram9: UUID="cb69d0af-4a52-4475-a139-7c17ef0a20f5" TYPE="swap"
/dev/zram10: UUID="7ec8a0e3-6cd7-4d14-aef9-ce722a8f3400" TYPE="swap"
/dev/zram11: UUID="04be0b67-18c1-43fe-84e7-e7053364ee7c" TYPE="swap"
/dev/zram12: UUID="86ae1532-7362-4966-9c48-b6a914759926" TYPE="swap"
/dev/zram13: UUID="502f415f-2cf5-4250-96f2-b4eed6207aeb" TYPE="swap"
/dev/zram14: UUID="518beb94-6173-4867-b36d-cd5ceb690f2c" TYPE="swap"
/dev/zram15: UUID="4a94c126-aef5-48b4-8129-d68e77df3d2d" TYPE="swap"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="d6661e71-96fe-4f9d-a950-cf56d7572139"
Garuda root is on nvme0n1p4 and home on sda1.
I'm not sure what I'm supposed to be checking here, how do I tell if a UUID is wrong?
SGS
18 February 2021 09:50
6
Dual boot with win?
The value "graphical.target reached after 7.198s in userspace" seem ok.
You are sure with 90 sec.?
If fstab is wrong your PC search long time for hardware on boot.
Shutdown could be save btrfs things and also if you save and boot with "Desktop Session".
and it is KDE , IIRC I have same, some times
Yeah win10 and garuda root on nvme, garuda home on sda.
It's the shutdown that's taking 90 seconds. Booting is fine every time.
I'm getting a new Desktop session every boot, so it must be btrfs.
petsam
18 February 2021 11:22
8
Check journal log of your last boot reversed
journalctl -b -1 -r
Don’t post the whole log. Review what happens from the moment you send the shutdown signal.
Mostly find this and time after that
systemd-logind[400]: System is powering down
90 seconds is a common timeout value. This probably indicates a process or service is not exiting when told to and is instead being killed by systemd after waiting 90 seconds.
You’ll have to pay attention to any log messages shown on screen during shutdown, and you can see the full journal for the previous boot using
journalctl -b -1
(please don’t just paste the output of that here - look at it to see which process is hanging)
Hello! Sorry, been quite busy!
My previous boot had a lot of these in the logs:
Feb 26 15:08:43 reticent-monolith kernel: amdgpu:
last message was failed ret is 0
Feb 26 15:08:37 reticent-monolith kernel: amdgpu:
failed to send message 148 ret is 0
Feb 26 15:08:34 reticent-monolith kernel: amdgpu:
Feb 26 15:08:31 reticent-monolith kernel: amdgpu:
failed to send message 5e ret is 0
Feb 26 15:08:28 reticent-monolith kernel: amdgpu:
Feb 26 15:08:25 reticent-monolith kernel: amdgpu:
failed to send message 146 ret is 0
Feb 26 15:08:22 reticent-monolith kernel: amdgpu:
SGS
26 February 2021 15:43
11
Use PrivateBin upper right to post the longer log.
"If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look."
That may or may not be related., therefore you should look first for a service or process that is triggering the 90 second timeout towards the very end of the log.
