Some apps want to display their presence in the tray. For example, Joplin can be set to start in minimized mode and show its icon in the tray. However, this works only if libappindicator-gtk3 is installed.
Since it is a feature that comes with Joplin and since Joplin is an option of for the first-setup, it might be appropriate to install the indicator package as well. I suspect this holds for other apps as well. (AUR shows it as an optional dependency.)
It isn't really a big deal, more like a minor annoyance because the icon is otherwise missing although the app is running.
