Just the regular update.
I edited the shorcuts from the settings menu, like have always done.
In the past they would save between reboots, now if i uncheck a box for a certain shortcut , it works as expected, but upon next reboot all the shortcuts that I have unchecked go back, this never was a problem for me until now.
Kernel: 6.10.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=96027b0c-1e9d-4b46-8fec-d7788ff1d4d4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: ASUSTeK product: ROG Strix G713RW_G713RW v: 1.0
Mobo: ASUSTeK model: G713RW v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713RW.323
date: 10/16/2022
ID-1: BAT0 charge: 78.7 Wh (100.0%) condition: 78.7/90.0 Wh (87.5%)
volts: 16.9 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
serial: <filter> status: full
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1385 high: 4757 min/max: 400/4935 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 3260 8: 4757 9: 400 10: 400 11: 3267 12: 3247
13: 400 14: 400 15: 3238 16: 400 bogomips: 105401
Device-1: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none off: DP-6,eDP-2
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24a0 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,
DP-2, DP-3, DP-4, DP-5, Writeback-1, eDP-1 bus-ID: 05:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 56.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: not-matched mapped: DP-0 pos: primary res: 2560x1440 dpi: 108
size: 600x350mm (23.62x13.78") diag: 695mm (27.35") modes: N/A
Monitor-2: not-matched mapped: DP-2 size-res: N/A modes: N/A
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti Laptop GPU driver: nvidia v: 560.35.03
device-ID: 10de:24a0 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.2.2-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
API: ALSA v: k6.10.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
vendor: AzureWave ASUS PCE-AXE59BT driver: mt7921e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7922 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A
mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3568
Local Storage: total: 953.87 GiB used: 843.62 GiB (88.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 31.9 C
used: 843.62 GiB (88.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.61 GiB used: 5.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 65.1 C mobo: 32.0 C
Fan Speeds (rpm): cpu: 3000
GPU: device: nvidia screen: :0.0 temp: 58 C device: amdgpu temp: 58.0 C
Memory: total: 32 GiB note: est. available: 30.61 GiB used: 6.55 GiB (21.4%)
Processes: 410 Power: uptime: 1h 1m states: freeze,mem,disk
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1940 libs: 561 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32 running-in: konsole
inxi: 3.3.35
System install date: 2022-12-31
Last full system update: 2024-09-09
Sorry for the bad format, I should know better, just frustrated.
