I don't know why this is happening but the shift key no longer works, if I use it to type a capital letter, nothing is printed, and same goes for special characters. I've resorted to using caps lock to type my capital letters but it's very inconvenient.
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=5411b7ff-d53c-4780-9b50-82a7b4183826 rw rootflags=subvol=@
Type: Laptop System: Acer product: Nitro AN515-57 v: V1.17
Mobo: TGL model: Scala_TLS v: V1.17 serial: <superuser required>
UEFI: Insyde v: 1.17 date: 06/02/2022
ID-1: BAT1 charge: 12.8 Wh (23.2%) condition: 55.1/57.5 Wh (95.8%)
volts: 14.6 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: discharging cycles: 77
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2048 high: 2300 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 901 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 1100 8: 873 9: 2300 10: 2300 11: 2300 12: 2300
13: 2300 14: 2300 15: 2300 16: 2300 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Acer Incorporated
ALI driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Acer
Incorporated ALI driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-08) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-9:3
chip-ID: 0408:a061 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau,vesa alternate: fbdev,nv gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Acer Incorporated ALI
bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.19.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.59 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 2.29 TiB used: 289.3 GiB (12.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 297.4 GiB size: 297.4 GiB (100.00%) used: 289.25 GiB
(97.3%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 50.6 MiB
(52.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 297.4 GiB size: 297.4 GiB (100.00%) used: 289.25
GiB (97.3%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 297.4 GiB size: 297.4 GiB (100.00%) used: 289.25
ID-5: /var/tmp raw-size: 297.4 GiB size: 297.4 GiB (100.00%) used: 289.25
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
Message: No sensor data found. Is lm-sensors configured?
Processes: 356 Uptime: 37m wakeups: 2 Memory: 15.41 GiB used: 2.59 GiB
(16.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2223
libs: 542 tools: octopi,paru,yay Shell: Bash v: 5.1.16
running-in: terminator inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-02-16
Last full system update: 2022-10-08 ↻
Failed units: nmb.service
when shift is pressed, no other inputs are acknowledged/recognized, along with the pressing of the shift key itself.
