Shift-Delete not working
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bfb33290-5d29-4ede-bf2c-a5843ccea654 rw rootflags=subvol=@
Type: Desktop Mobo: N/A model: N/A serial:
uuid: UEFI: American Megatrends v: 5.12
date: 11/10/2018
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 650 high: 800 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 400
5: 800 6: 800 7: 400 8: 400 bogomips: 30399
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: DP-1,HDMI-A-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0c45:64a1
class-ID: 0e02
Screen-1: 0 s-res: 2944x1080 s-dpi: 96 s-size: 776x285mm (30.55x11.22")
s-diag: 827mm (32.55")
Monitor-1: DP-1 pos: bottom-l res: 1024x768 hz: 60 size: N/A modes:
max: 640x480 min: 848x480
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary,top-right
model: Samsung C32F391 serial: built: 2019 res: 1920x1080 hz: 60
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 15.05 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.0.1-arch1.1
device-ID: 8086:5917 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:0034 class-ID: 0280
IF: wlp2s0 state: down mac:
Device-1: Toshiba Atheros AR3012 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 0930:021c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: bt-v: 4.1
lmp-v: 7 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 2.96 TiB used: 1.35 TiB (45.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: fw-rev: ELFK0S.6 temp: 52.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Backup+ SL
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial:
fw-rev: 0143 scheme: MBR
model: WD20NMVW-11EDZS2 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5200 serial: fw-rev: 1012 scheme: MBR
used: 73.36 GiB (31.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C pch: 43.5 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.41 GiB used: 4.02 GiB (26.1%)
Processes: 261 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1474 libs: 437 tools: gnome-software, octopi,
pamac, paru Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-07
Last full system update: 2024-02-19 ↻
Hi
Im sitting with a problem I have never had before.
I am trying to permanently delete some folders. Usually ctrl-mouseclick would highlight the folder and shift-del would permantly delete the folder.
Now shift-del does nothing. If I right-click the folder, the option to delete is greyed out. If I open the folder I can del each item with the right-click menu. Del also deletes single items or all selected items. However shift-del does not work.
Please advise.
I also checked the pull-down menu and both del, shift-del were greyed out when I selected a folder.
So, please reboot and format like
Is this about a file browser, and if so, which one is it?
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Type: Desktop Mobo: N/A model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 5.12
date: 11/10/2018
Speed (MHz): avg: 479 high: 733 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 700 4: 400
5: 400 6: 400 7: 400 8: 733 bogomips: 30399
class-ID: 0e02
model: Samsung C32F391 serial: <filter> built: 2019 res: 1920x1080 hz: 60
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api tools: N/A
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 0930:021c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.1
Local Storage: total: 2.96 TiB used: 73.55 GiB (2.4%)
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 56.9 C
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
tech: HDD rpm: 5200 serial: <filter> fw-rev: 1012 scheme: MBR
used: 73.55 GiB (31.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 49.0 C pch: 45.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.41 GiB used: 3.63 GiB (23.5%)
Processes: 285 Power: uptime: 0m states: freeze,mem,disk suspend: deep
Garuda (2.6.23-1):
This is not for a terminal. This is for dolphin.
Never had a problem before. I reformatted my system just before the weekend so maybe something there. Thank you
What’s this all about? You plan on fixing this?
This is an upstream systemd bug. I too have had it for a while and likely you do too. Check your jctl output.
Check if this the case for you
https://bugs.kde.org/show_bug.cgi?id=394001
Actually there are several duplicates, as usual, e.g.
https://bugs.kde.org/show_bug.cgi?id=473539
Where do you read terminal? :slight_smile:
But you did not edit your first post.
I assume that you want to delete files in the system folder /, this is not so easy for a good reason, it is best to do this from the Konsole here in KDE to avoid having to write Terminal.
If it should be in the home folder, which still works for me, then the 6-year-old bug has hit you :smiley:
I’ve not seen it it my inxi output before, but I meet very few of the same conditions. I’ll check later today when I’m in Arch.
Thanks for the heads-up! :slight_smile:
Have read a fair amount of posts about the and still dont now how to fix the virtual console issue. Last year I found a post that sorted it in 1 command. (Cant find it again gah!)
Not sure what the 6 year bug is??
Sorry about saying “terminal”
All I want to do is shift-del folders on my external drive which are no longer needed - aka cleanup.
But never had the issue before except with this latest full reinstall about 2 weeks ago.
Filo, yes that is the issue. Just want to completely delete a file with the shortcut.
Yet it works if i permanently delete a file. Thanks
If the KDE bug is your issue, have you checked in System Settings > Shortcuts > Standard Shortcuts (hope this is the correct place) if you have a Shift+Delete shortcut assigned to Cut and, if so, deleted it?
That was the first place I checked and nothing there besides meta+E.
Not really sure how to create the custom shortcut for this.
But I have always been able to shift-del???
It is related to the vconsole error. Solve that, and you solve your problem.
