Please see the pastebin for more info.
Probably related to java and xtreme download manager
If you dont use it you can remove it from autostart
I use it some times, but I really prefer the built-in browser download manager.
Thanks
Yes, removing it from autostart is the best solution. I wouldn't uninstall it, it comes in real handy at times for those flakey downloads you may encounter. It can easily be started when you find you need it.
