Could you do the following please, to test if that works for you:
sudo micro /usr/bin/setup-assistant
-> Change line 66 to eg: (or any other site which should be always up)
wget -q --spider http://github.com
Save and run the assistant again.
# Because this can never be offline, right?
# wget -q --spider http://garudalinux.org
return $?
Yes it worked for me. The dialog menu has opened.
This will permanently fix the problem or is it a test.?
It was a test but I’ll change it later as that seems to be the better option
