Hi folks. I just downloaded a fresh copy of the Garuda KDE Dr460nized iso and made a bootable USB installer with Etcher. I installed the OS to my older PC. The initial install went fine. I ran the setup-assistant immediately after first boot. After completing the multiple screen process, it and asked if I wanted to remove the setup-assistant—I said no—and then it closed and returned me to Garuda Welcome without installing anything.
I opened Konsole and ran setup-assistant from there and got the following messages during the process of completing multiple pages of forms:
** (yad:24189): WARNING **: 22:11:42.862: Unable to connect to dbus: Error spawning command line “dbus-launch --autolaunch=fe7fbb620adf4e10942620c9ee0cc511 --binary-syntax --close-stderr”: Child process exited with code 1
(yad:24189): GLib-GIO-CRITICAL **: 22:11:42.919: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(yad:24189): GLib-GIO-CRITICAL **: 22:11:42.919: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
Created log file at "/tmp/Alacritty-26642.log"
[2021-04-05 22:14:33.504223261] [ERROR] [alacritty] Alacritty encountered an unrecoverable error:
There was an error initializing the shaders: Failed compiling shader: 0:1(10): error: GLSL 3.30 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES
Created log file at "/tmp/Alacritty-27745.log"
[2021-04-05 22:15:43.685763194] [ERROR] [alacritty] Alacritty encountered an unrecoverable error:
So... no luck running setup-assistant. Has anyone else experienced this? Can you suggest a fix or a work-around?
I do appreciate this community and I hope someone has a solution.
