Settings Changing After Reboot
Hola Amigos !
So I’ve had a fresh install of Garuda . The issue I face is that After Installing some specific packages , there seems to be a log in the terminal , Reloading Device Manager Configuration , after which all my audio device settings are reset such as volume . Well they are restored to original after a reboot , it still is very inconvenient to re-configure the audio devices or perform a reboot after each package transaction .
My main concern is this being a big underlying issue with my installation .
inxi:
root=UUID=0e89091d-2ebf-4c17-b3f8-afa3607be55a rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop System: HP product: HP All-in-One 22-df0xxx v: N/A
serial: <superuser required> Chassis: type: 13 serial: <superuser required>
Mobo: HP model: 87A4 v: 10100 serial: <superuser required> UEFI: AMI
v: F.36 date: 08/07/2023
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC2
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1508 high: 1552 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1400 2: 1543 3: 1540
4: 1552 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:7
chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 7.35 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:8a56 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:6 chip-ID: 0bda:b00a
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 975.29 GiB used: 8.26 GiB (0.8%)
model: WD10EZEX-60WN4A1 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A03 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Cruzer Blade
size: 14.53 GiB block-size: physical: 512 B logical: 512 B type: USB
ID-1: / raw-size: 243.1 GiB size: 243.1 GiB (100.00%) used: 8.26 GiB (3.4%)
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 243.1 GiB size: 243.1 GiB (100.00%)
used: 8.26 GiB (3.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 243.1 GiB size: 243.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 243.1 GiB size: 243.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 197 Uptime: 18m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.53 GiB used: 2.51 GiB (33.3%) Init: systemd v: 254
pm: pacman pkgs: 1333 libs: 399 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date:     2023-11-17
Last full system update: 2023-11-17
All help is appreciated !
Rebooting after a system upgrade is recommended anyways. Garuda even adds a check for this in the garuda-inxi. Not to mention, things like a kernel version upgrade will not be in use until a reboot.
Yes a reboot is certain after an update but is it necessary after installing something like gparted or standard package transactions as well ?
It is always best practice if something is not working correctly, to first try a reboot to see if it fixes the issue. On a fresh system, rebooting is a must after the first update.
After the initial setup with setup assistant, I had rebooted and then tried to install gparted , which installed udftools , udftools triggers that Reloading Device Manager configuration and the settings get altered .
I did all of this after rebooting after an update.
If this trigger Reloading Device… happens after any transaction, any , apart from updates where this happens but we are supposed to reboot , then the settings get altered.
