Hi, I downloaded the "nordvpn-bin" but not sure how to use it. It comes up in my menu but doesn't open. It appears to maybe use the terminal. I'm used to Windows with GUIs and simple connect buttons lol. I'm pretty novice with networking besides the basics. What's the best way to use Nord VPN? I know there are several ways but I'm not sure which is simpliest.
It's really easy to use, you just have to learn a few commands. Read the wiki page SGS linked, that tells you everything you need to know. If you forget a command or syntax while you are using it, just type nordvpn --help
for a quick reminder.
