Setting to change between Classic, Wayland, Xorg etc seems to be missing
Hi,
I don't know how and why, but the little configuration-wheel is just missing in my gdm. I do know that I can manually direct the system to use wayland or xorg or whatever, but I wondered if it's just me or if this is a general issue.
Inxi:
 ╰─λ garuda-inxi
  Kernel: 6.3.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=b9afbce6-e3ee-4de7-a576-155918220e43 rw rootflags=subvol=@
    resume=UUID=680cabbd-0a46-4b76-857e-79094f9d4d50 loglevel=3 ibt=off
  Desktop: GNOME v: 44.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: H.I0
    date: 08/10/2022
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3494 high: 3841 min/max: 2200/4662 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
    3: 3841 4: 3400 5: 3400 6: 3400 7: 3681 8: 3607 9: 3598 10: 3589 11: 3590
    12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 bogomips: 108809
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2,DP-3,HDMI-A-1 bus-ID: 2f:00.0 chip-ID: 1002:73bf
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
    s-diag: 987mm (38.84")
  Monitor-1: DP-1 mapped: DisplayPort-0 model: M40-144 serial: <filter>
    built: 2021 res: 3440x1440 dpi: 94 gamma: 1.2 size: 926x387mm (36.46x15.24")
    diag: 995mm (39.2") modes: max: 3440x1440 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.1.2 renderer: AMD Radeon RX 6800 (navi21 LLVM
    15.0.7 DRM 3.52 6.3.7-zen1-1-zen) direct-render: Yes
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
    bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: ASUSTek Xonar SoundCard driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
    chip-ID: 0b05:189d class-ID: 0300
  Device-4: Corsair HS80 RGB Wireless Gaming Receiver
    lanes: 1 mode: 1.1 bus-ID: 7-1:2 chip-ID: 1b1c:0a6b class-ID: 0300
  API: ALSA v: k6.3.7-zen1-1-zen status: kernel-api tools: N/A
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:3 chip-ID: 0b05:190e
  Local Storage: total: 3.18 TiB used: 1.1 TiB (34.6%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
    fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:7 vendor: Western Digital
    model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 711240WD temp: 39.9 C scheme: GPT
  ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
  ID-1: / raw-size: 862.23 GiB size: 862.23 GiB (100.00%)
    used: 457.02 GiB (53.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 25.9 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 862.23 GiB size: 862.23 GiB (100.00%)
  ID-4: /var/log raw-size: 862.23 GiB size: 862.23 GiB (100.00%)
  ID-5: /var/tmp raw-size: 862.23 GiB size: 862.23 GiB (100.00%)
  ID-1: swap-1 type: partition size: 68.99 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 62.71 GiB used: 1.5 MiB (0.0%) priority: 100
  System Temperatures: cpu: 45.0 C mobo: 36.0 C gpu: amdgpu temp: 46.0 C
    mem: 42.0 C
  Fan Speeds (RPM): fan-1: 622 fan-2: 528 fan-3: 471 fan-4: 644 fan-5: 819
    fan-6: 0 fan-7: 683 gpu: amdgpu fan: 658
  Processes: 500 Uptime: 3m wakeups: 0 Memory: available: 62.71 GiB
  used: 4.22 GiB (6.7%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1797 libs: 519 tools: pamac,paru,yay Shell: fish v: 3.6.1
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
  System install date:     2023-02-24
  Last full system update: 2023-06-13
just to be clear what I mean by that
The marked settings icon is just missing in my gdm.
Edit. Nevermind I guess, installed KDE Plasma and there it is again, only with "Plasma" and "Gnome" as options, nothing else. Well...
