Hi all,
I tried to change my system-wide path, but for some reason it does not work for me. I installed a few binaries in a subfolder under /opt
, and want to add this subfolder to the system path. I created 2 new files under /etc/profile.d/
- one is the .sh
variant, the other is the .csh
variant. The contents are as follows:
[ -d /opt/JLink ] && append_path '/opt/JLink'
export PATH
and
[ -d /opt/JLink ] && setenv PATH ${PATH}:/opt/JLink
Both files are owned by root and have permissions 644. The directory exists and is spelled correctly. However, when I reboot/relogin, my path only shows:
╭─[email protected] in ~ took 74ms
╰─λ echo $PATH
/usr/local/sbin /usr/local/bin /usr/bin /usr/bin/site_perl /usr/bin/vendor_perl /usr/bin/core_perl
I also tried with creating the folder ~/.config/environment.d/
and then adding a file path.conf
with the contents PATH=${PATH}:/opt/JLink
as per the Arch Wiki, but that did not work either.
I am using Garuda Dragonized KDE edition and my shell is Fisch. (I also want the extended PATH to be available for other applications outside of Fisch).. Here is my system info:
inxi output
System: Kernel: 5.11.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=99d0c990-60c6-4faf-86ee-17a4aa79cc5e rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=cd59ffac-afc3-40a2-bb41-7efe054d6ff4 loglevel=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Dell product: XPS 15 9550 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0Y9N5X v: A08 serial: <filter> UEFI: Dell v: 1.14.0 date: 02/13/2020
Battery: ID-1: BAT0 charge: 84.0 Wh (100.0%) condition: 84.0/84.0 Wh (100.0%) volts: 12.4 min: 11.4 model: SMP DELL 1P6KD54
type: Li-poly serial: <filter> status: Full
Device-1: hid-0003:256F:C652.0008-battery model: 3Dconnexion Universal Receiver serial: N/A charge: N/A status: N/A
CPU: Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S family: 6 model-id: 5E (94)
stepping: 3 microcode: E2 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41599
Speed: 3495 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3495 2: 3201 3: 3266 4: 3158 5: 3428 6: 3196 7: 3285
8: 3141
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel HD Graphics 530 vendor: Dell XPS 15 9550 driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell XPS 15 9550 driver: nvidia v: 460.67
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:139b class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-12:5 chip-ID: 0c45:6713 class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1353x380mm (53.3x15.0") s-diag: 1405mm (55.3")
Monitor-1: DP1-1 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
Monitor-2: DP1-2 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell XPS 15 9550 driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: Focusrite-Novation Scarlett 2i2 Camera type: USB driver: snd-usb-audio,usb-storage bus-ID: 3-2.1:3
chip-ID: 1235:8210 class-ID: 0806 serial: <filter>
Device-3: Microsoft LifeCam Studio type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 3-2.3.3.1:9
chip-ID: 045e:0772 class-ID: 0300
Device-4: Realtek USB Audio type: USB driver: snd-usb-audio bus-ID: 3-2.3.4:8 chip-ID: 0bda:402e class-ID: 0102
Sound Server-1: ALSA v: k5.11.10-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.17 running: no
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 8086:2526
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 4-2.4:7 chip-ID: 0bda:8153
IF: enp11s0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 8087:0025
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 476.94 GiB used: 118.65 GiB (24.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: Acer VT500M M.2 NVME 512G size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: S0614B0G temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: Scarlett Welcome Disk size: 192 KiB block-size: physical: 512 B
logical: 512 B serial: <filter> rev: 0.10 scheme: MBR
Partition: ID-1: / raw-size: 442.34 GiB size: 442.34 GiB (100.00%) used: 118.65 GiB (26.8%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 442.34 GiB size: 442.34 GiB (100.00%) used: 118.65 GiB (26.8%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 442.34 GiB size: 442.34 GiB (100.00%) used: 118.65 GiB (26.8%) fs: btrfs
ID-5: /var/tmp raw-size: 442.34 GiB size: 442.34 GiB (100.00%) used: 118.65 GiB (26.8%) fs: btrfs
ID-1: swap-1 type: partition size: 34.34 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: swap-2 type: zram size: 3.9 GiB used: 768 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 3.9 GiB used: 768 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 3.9 GiB used: 768 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 3.9 GiB used: 512 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 3.9 GiB used: 512 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 3.9 GiB used: 512 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 3.9 GiB used: 512 KiB (0.0%) priority: 32767 dev: /dev/zram6
Sensors: System Temperatures: cpu: 69.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3220 fan-2: 3215
Info: Processes: 312 Uptime: 32m wakeups: 2 Memory: 31.21 GiB used: 7.51 GiB (24.0%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1589 lib: 359 Shell: fish v: 3.2.1 running-in: alacritty
inxi: 3.3.03
Thanks for your help!
