Setfont: KDFONTOP: Function not implemented
Hello there, this is my first post so please be gentle haha. I have been experiencing this issue on boot where many times it will hang on the boot screen with the message: setfont: KDFONTOP: Function not implemented
I have searched the forums and the solutions that were suggested didnt work for me. I have been usually just ignoring this and powering on and off my laptop until it boots but it is getting progressively worse and i finally feel like I need to get an actual long-term solution to stop this from happening. I literally just now had to power off and off 5 times to get it to boot into Garuda.
Thank you.
Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=fff150b2-71d0-43d0-ae96-da99435eae6e rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: XPS 15 7590 v: N/A
Mobo: Dell model: 0VYV0G v: A00 serial: <superuser required> UEFI: Dell
v: 1.20.0 date: 12/23/2022
ID-1: BAT0 charge: 60.8 Wh (100.0%) condition: 60.8/97.0 Wh (62.7%)
volts: 12.6 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: full
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1537 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 2600 3: 2600
4: 900 5: 900 6: 900 7: 900 8: 2600 bogomips: 41599
ports: active: DP-3,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0c45:6723 class-ID: 0e02
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x571mm (80.00x22.48")
s-diag: 2111mm (83.1")
Monitor-1: DP-3 pos: primary,left model: HDMI1 serial: <filter>
built: 2020 res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2
size: 620x348mm (24.41x13.7") diag: 711mm (28") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: eDP-1 pos: right model: Samsung 0xa029 built: 2019
res: 3840x2160 hz: 60 dpi: 284 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
API: ALSA v: k6.2.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 3b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 238.47 GiB used: 52.31 GiB (21.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZHPU256HCGL-00000
type: SSD serial: <filter> rev: 401Q scheme: GPT
used: 52.31 GiB (22.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.26 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 79.0 C pch: 37.0 C mobo: 43.0 C
Fan Speeds (RPM): cpu: 3389 fan-2: 3401
Processes: 300 Uptime: 5m wakeups: 14 Memory: 15.26 GiB
used: 4.28 GiB (28.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1664
libs: 493 tools: octopi,pamac,paru,yay Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date:     2023-03-12
Last full system update: 2023-04-02
Welcome!
edit:
I don't think the boot problem is related though.
On a side note, since a while I'm occasionally experiencing random boot failure.
I used to think my laptop was about to die, now I suspect something with the graphics card driver.
You may want to open another thread for that issue.
