Kernel: 6.5.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=118d0a3d-bd36-4af5-b1fe-50bdadb995c9 rw rootflags=subvol=@
resume=UUID=1a255bd2-7043-4ff3-8aa4-10b3ef87f4e8 loglevel=3 ibt=off
Type: Laptop System: HP product: HP Laptop 15-ef2xxx v: N/A
Mobo: HP model: 887A v: 59.21 serial: <superuser required> UEFI: AMI
v: F.27 date: 10/20/2022
ID-1: BAT0 charge: 42.0 Wh (100.0%) condition: 42.0/42.0 Wh (100.0%)
volts: 12.9 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608104
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1029 high: 2196 min/max: 400/4056 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1720 2: 1894 3: 400
4: 1777 5: 400 6: 1972 7: 400 8: 400 9: 400 10: 400 11: 400 12: 2196
bogomips: 50303
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 47.0 C
Device-2: Luxvisions Innotech [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 30c9:0013
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0949 built: 2020
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.5.8-zen1-1-zen) device-ID: 1002:164c memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:164c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.8-zen1-1-zen status: kernel-api with: aoss
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
Device-1: Realtek [] driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 0bda:b00c class-ID: e001
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1.14 TiB used: 18.93 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 HFM256GD3JX013N size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS1 temp: 19.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04UBF100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 18.93 GiB (2.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.09 GiB used: 445.2 MiB (6.1%)
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 52.9 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Processes: 313 Uptime: 24m wakeups: 120 Memory: total: 8 GiB note: est.
available: 7.09 GiB used: 3.28 GiB (46.3%) Init: systemd v: 254
pm: pacman pkgs: 1823 libs: 526 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-25
Last full system update: 2023-10-25 ↻
I did some research and I know the solution is already posted somewhere however I’ve been unable to find and or understand how to solve the issue from what I’ve read so far.
I know all I have to do is change the audio device how the GUI isn’t showing me the “Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard” which I need to be using.
“Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard” is enabled by default and is not what I need.
Thanks in advance.
