Segfaults happening
This is the second time in the past week I where shortly after booting and logging into gnome, my whole system freezes and I have to cold boot. Both times I noticed a segmentation fault in the system log after rebooting:
First time:
Compositor[18431]: segfault at 8 ip 000055bd26c7e00b sp 00007f6fdbfae070 error 4 in vivaldi-bin[55bd25d6c000+b0da000] likely on CPU 3 (core 1, socket 0)
Second time:
bijiben-shell-s[6418]: segfault at 7f3a13de3ac9 ip 00007f3e0e01ef41 sp 00007ffd4b20c7c8 error 4 in libgobject-2.0.so.0.7800.3[7f3e0dff3000+35000] likely on CPU 14 (core 7, socket 0)
Any ideas?
ty
  Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=cc8f8aae-9afb-48fc-9eff-62f9df1eb56c rw rootflags=subvol=@
    cryptdevice=UUID=cfffcf8a-c3da-46b8-b9c9-b4bc281caba8:luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
    root=/dev/mapper/luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8 no
    resume=/dev/mapper/luks-4a58206a-a094-481e-8f36-013e250bfae4 loglevel=3
    no nvidia-drm.modeset=1 systemd.unified_cgroup_hierarchy=false
    pcie_aspm=off ibt=off
  Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM
    v: 45.0.1 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503RM_GA503RM
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: GA503RM v: 1.0 serial: <filter> UEFI: American
    Megatrends LLC. v: GA503RM.313 date: 01/17/2023
  ID-1: BAT1 charge: 4.5 Wh (5.7%) condition: 79.0/90.2 Wh (87.6%) volts: 14.7
    min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A status: charging
  Info: model: AMD Ryzen 9 6900HS with Radeon Graphics socket: FP7 bits: 64
    type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
    process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
    microcode: 0xA404101
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 550 high: 1705 min/max: 400/4935 base/boost: 3300/4925
    scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
    ext-clock: 100 MHz cores: 1: 1500 2: 400 3: 400 4: 400 5: 400 6: 400
    7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 1705
    16: 400 bogomips: 105406
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    off: eDP-2 empty: DP-9,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520
  Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, eDP-1 bus-ID: 07:00.0
    chip-ID: 1002:1681 class-ID: 0300 temp: 53.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:56eb
  Display: server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
    s-diag: 777mm (30.58")
  Monitor-1: eDP-2 mapped: DP-2 note: disabled model: ChiMei InnoLux 0x1540
    built: 2020 res: 2560x1440 dpi: 191 gamma: 1.2 size: 340x190mm (13.39x7.48")
    diag: 394mm (15.5") ratio: 16:9 modes: 2560x1440
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
    GPU/PCIe/SSE2 memory: 5.86 GiB
  API: Vulkan v: 1.3.274 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 545.29.06
    device-ID: 10de:2520 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV REMBRANDT) driver: mesa radv
    v: 23.3.1-arch1.1 device-ID: 1002:1681 surfaces: xcb,xlib device: 2
    type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
    v: 23.3.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
    bus-ID: 07:00.1 chip-ID: 1002:1640 class-ID: 0403
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
    class-ID: 0480
    bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
    vendor: AzureWave ASUS PCE-AXE59BT driver: mt7921e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7922 class-ID: 0280
  IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3568
  Local Storage: total: 1.38 TiB used: 383.91 GiB (27.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
    model: SHPP41-1000GM size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 51060A20 temp: 54.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Western Digital model: WD PC
    SN735 SDBPNHH-512G-1002 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 70626000 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
    used: 383.91 GiB (85.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
    used: 732 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
    maj-min: 259:8
  ID-3: /home raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
  ID-4: /var/log raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
  ID-5: /var/tmp raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 22.76 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 25.05 GiB used: 0 KiB (0.0%)
    mapped: luks-4a58206a-a094-481e-8f36-013e250bfae4
  System Temperatures: cpu: 60.9 C mobo: 38.0 C
  Fan Speeds (rpm): cpu: 3500
  GPU: device: nvidia screen: :1.0 temp: 47 C device: amdgpu temp: 55.0 C
  Processes: 450 Uptime: 11m wakeups: 0 Memory: total: 24 GiB note: est.
  available: 22.76 GiB used: 6.29 GiB (27.6%) Init: systemd v: 255
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12/6/7
  clang: 16.0.6 Packages: pm: pacman pkgs: 2475 libs: 601
  tools: gnome-software,pamac,paru Shell: garuda-inxi (sudo) default: Bash
  v: 5.2.21 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.21-1):
  System install date:     2022-10-15
  Last full system update: 2023-12-24
  Windows dual boot:       Yes
  Failed units:            anbox-container-manager.service postgresql.service
As I wrote @lum1nuss , nobody reads the template.
  • ONE issue per topic.
The instruction would probably be better if you got rid of the part about “Hide details” and instead just say “Your inxi output MUST BE IN A CODEBLOCK.” I put it in hide details because I skimmed the instructions, and when my brain got to the hide details part, I thought “This must be a feature to ensure only forum members can see your inxi.”
It’s obviously my fault for not giving it more attention but I’m willing to bet others have done the same.
Lol, but at least it’s easier to read now :smiley:
Fair point on the “It must be in a codeblock”, it’s more concise :slight_smile: thank you for the suggestion!
my garuda-inxi
It’s really big so I put it here
Back on topic, have you tried running a memtest?
Do the segfaults happen if you log in and just leave the laptop alone? The first one is Vivaldi-related, but the second one is some shell.
There’s a chance this issue may be related:
I just noticed the bijiben error, and found people having similar segfaults before circling back here.
https://bbs.archlinux.org/viewtopic.php?id=234127
Looking into these now
