Hey all! I'm having an issue with my second monitor. I do not know what caused this, but while I was working on a project on my computer, my second monitor suddenly blanked. It no longer shows up in the display settings, however, it works perfectly fine when using Windows, booting, and on the login screen (the screen isn't even mirrored, it's registered as a second display entirely.)
Reverting to a previous snapshot fixes this, but I can't do this because I have important progress made with my project on my current snapshot that would be reverted by going to a previous one.
I have a Ryzen 7 2700X and an R5 570 if this information helps.
If anyone has any ideas as to what the issue could be, please let me know, and thank you in advance!
Can we have your
as per the forum template
Where?
In / or /home?
Snapshots only restore / (in the default setting).
Can we have your
my b, first post please have mercy lol
Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=090e07fa-a3f4-4381-9c56-964c51078bd8 rw [email protected]
Desktop: KDE Plasma v: 5.25.0 tk: Qt v: 5.15.4 info: latte-dock
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F2 date: 08/08/2018
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2760 high: 4343 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3213 2: 2380
3: 2706 4: 2480 5: 2390 6: 2418 7: 2465 8: 2410 9: 2853 10: 2492 11: 2447
12: 2452 13: 4159 14: 4343 15: 2482 16: 2481 bogomips: 118162
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 off: DVI-D-1 empty: DP-1,DP-2,DP-3 bus-ID: 06:00.0
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-3:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled model: Acer R240HY
serial: <filter> built: 2019 res: N/A dpi: 93 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary
model: LG (GoldStar) FULL HD built: 2016 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 13.0.1 DRM
3.46 5.18.5-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 1-1:2 pcie:
chip-ID: 0499:1009 class-ID: ff00 gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.3
Device-3: Yamaha UX16 MIDI I/F type: USB driver: snd-usb-audio
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: 0d8c:0005
Device-5: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Device-6: SAVITECH SA9123 USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 262a:9113
class-ID: 0102
Device-7: DisplayLink Dell Universal Dock D6000 type: USB
driver: cdc_ncm,snd-usb-audio bus-ID: 5-2.1:5 chip-ID: 17e9:6006
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp7s0f3u2u1i5 state: down mac: <filter>
Local Storage: total: 1.84 TiB used: 158.64 GiB (8.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC63
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU760 size: 953.87 GiB
serial: <filter> rev: 4R07 scheme: GPT
used: 158.63 GiB (16.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.57 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 49.9 C mobo: 16.8 C gpu: amdgpu temp: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1111
Processes: 359 Uptime: 30m wakeups: 0 Memory: 15.57 GiB
used: 3.47 GiB (22.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1745
lib: 509 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.18
Garuda (2.6.3-2):
System install date: 2022-01-24
Last full system update: 2022-06-18
Where?
In / or /home?
/home, i wasnt aware it'd only revert /
i will try doing this
It maybe worth looking at the last pacman log to see which update may be breaking your system
s a i n t
logs told me this:
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] >>> This driver now uses DRI3 as the default Direct Rendering
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] Infrastructure. You can try falling back to DRI2 if you run
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] into trouble. To do so, save a file with the following
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] content as /etc/X11/xorg.conf.d/20-intel.conf :
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] Section "Device"
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] Identifier "Intel Graphics"
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] Driver "intel"
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] Option "DRI" "2" # DRI3 is now default
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] #Option "AccelMethod" "sna" # default
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] #Option "AccelMethod" "uxa" # fallback
[2022-01-24T17:23:16-0600] [ALPM-SCRIPTLET] EndSection
creating a 20-intel.conf file (even though i have an... amd... card..... also i didnt have to put anything in there at all) suddenly revived my second monitor. It probably shouldve been my first instinct to check logs haha
thank you to the both of you!
