jthro
February 5, 2023, 2:22am
1
I am having a strange issue only on my second monitor (not the one that came with my laptop) where the screen wobbles more the further to the right along.
I have tried:
Wiping the monitor
Rebooting
Installing proprietary nvidia drivers
Changing the aspect ratio
None have solved the issue. Help would be appreciated.
Monitor is an old Samsung 22"
Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=a59f8ead-458a-4d93-92a2-588075e2d4b8 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Acer product: Aspire A715-51G v: V1.04
serial:
Mobo: ADL model: Metis_ADP v: V1.04 serial:
UEFI: INSYDE v: 1.04 date: 04/09/2022
ID-1: BAT1 charge: 50.1 Wh (100.0%) condition: 50.1/47.8 Wh (104.8%)
volts: 12.9 min: 11.2 model: LGC AP18C8K type: Li-ion serial:
status: full
Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1558 high: 2100 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 746 2: 2100 3: 800
4: 2100 5: 669 6: 2100 7: 632 8: 2100 9: 654 10: 2100 11: 440 12: 2100
13: 2100 14: 2100 15: 2100 16: 2100 bogomips: 67584
Device-1: Intel Alder Lake-P Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: HDMI-A-1,eDP-1
empty: DP-1,DP-2 bus-ID: 0000:00:02.0 chip-ID: 8086:4626 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nouveau v: kernel non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-3: Quanta ACER HD User Facing type: USB driver: N/A bus-ID: 3-6:6
chip-ID: 0408:4033 class-ID: fe01 serial:
Display: x11 server: [X.Org](http://X.Org) v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915 display-ID: :1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right
model: Samsung S22B350 serial: built: 2012 res: 1920x1080 hz: 60
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
Monitor-2: eDP-1 pos: left model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
missing.
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
bus-ID: 3-1.3:9 alternate: snd_hda_intel,snd_sof_pci_intel_tgl
chip-ID: 2516:0131 bus-ID: 0000:00:1f.3 class-ID: 0300 chip-ID: 8086:51c8
class-ID: 0401
Device-2: Cooler Master CH321 type: USB
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:4 chip-ID: 08bb:2902
Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel bus-ID: 0000:3d:00.0
chip-ID: 14c3:7961 class-ID: 0280
IF: wlp61s0 state: up mac:
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:3e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp62s0 state: down mac:
Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-10:8 chip-ID: 04ca:3802 class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address:
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 13.37 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDQNQD-512G-1014 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial:
rev: 73101100 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 229.49 GiB size: 229.49 GiB (100.00%)
used: 13.31 GiB (5.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 58.8 MiB (23.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 229.49 GiB size: 229.49 GiB (100.00%)
ID-4: /var/log raw-size: 229.49 GiB size: 229.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.49 GiB size: 229.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 28.0 C
Processes: 321 Uptime: 6m wakeups: 1 Memory: 15.33 GiB
used: 2.83 GiB (18.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1134
libs: 347 tools: pamac,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-02-04
Last full system update: 2023-02-05
It looks like it didn’t quite work. Have you tried installing with the Garuda Settings Manager?
Garuda Settings Manager → Hardware Configuration → click the Auto Install button.
jthro
February 5, 2023, 3:04am
3
I did this and proprietary drivers are now definitely installed. This did not however resolve the issue.
After running an update, terminal spat out this:
A problem with the NVIDIA drivers has been detected
Building NVIDIA DKMS module for kernel 6.1.9-arch1-1**
Module nvidia 525.85.05 is not installed for kernel 6.1.9-arch1-1 (x86_64). Skipping...
Module nvidia 525.85.05 is not built for kernel 6.1.9-arch1-1 (x86_64). Skipping...
Sign command: /usr/lib/modules/6.1.9-arch1-1/build/scripts/sign-file Binary /usr/lib/modules/6.1.9-arch1-1/build/scripts/sign-file not found, modules won't be signed Error!
Your kernel headers for kernel 6.1.9-arch1-1 cannot be found at /usr/lib/modules/6.1.9-arch1-1/build or /usr/lib/modules/6.1.9-arch1-1/source. Please install the linux-headers-6.1.9-arch1-1 package or use the --kernelsourcedir option to tell DKMS where it's located. **--->** **
Failed to build NVIDIA DKMS module for kernel 6.1.9-arch1-1**
SGS
February 5, 2023, 3:09am
5
Naman
February 5, 2023, 6:24am
6
Did you install that kernel yourself?
jthro
February 5, 2023, 9:18am
7
No. I booted it from the gnome distro on the garuda website.
jthro
February 5, 2023, 9:21am
8
Installed headers as per these instructions.
jthro
February 5, 2023, 9:26am
9
Problem still persists. It is not an issue with the monitor as I am dual booting windows and that works just fine.
Naman
February 5, 2023, 10:36am
10
First of all, have you tried matching there refresh rate? I mean set 144 Hz on both, or if 1 of the monitor is not capable of that, set 60 Hz refresh rate for both monitors.
Please Report back if it solves issue or not
jthro
February 5, 2023, 10:55am
11
Set both to 60Hz, didn't fix the issue.
jthro:
Hmm, this error message is odd because you are not using this kernel.
Can you post the input and output of these commands into the thread:
garuda-update
sudo pacman -S linux-zen linux-zen-headers nvidia-dkms
jthro
February 5, 2023, 10:32pm
13
garuda-update:
garuda 96.9 KiB 135 KiB/s 00:01 [------------------------------------] 100%
core 155.4 KiB 456 KiB/s 00:00 [------------------------------------] 100%
extra 1739.1 KiB 2.41 MiB/s 00:01 [------------------------------------] 100%
community 7.2 MiB 3.78 MiB/s 00:02 [------------------------------------] 100%
multilib is up to date
chaotic-aur 2.3 MiB 2.82 MiB/s 00:01 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
resolving dependencies...
Packages (5) bash-5.1.016-3 filesystem-2023.01.31-1 garuda-backgrounds-r15.cd07442-1
grub-2:2.06.r456.g65bc45963-1 htop-3.2.2-1
Total Download Size: 69.30 MiB
Total Installed Size: 103.03 MiB
Net Upgrade Size: 0.75 MiB
:: Retrieving packages...
filesystem-2023.01.31-1-x86_64 14.7 KiB 117 KiB/s 00:00 [------------------------------------] 100%
htop-3.2.2-1-x86_64 147.3 KiB 892 KiB/s 00:00 [------------------------------------] 100%
bash-5.1.016-3-x86_64 1718.6 KiB 2.10 MiB/s 00:01 [------------------------------------] 100%
grub-2:2.06.r456.g65bc45963-1-x86_64 6.8 MiB 4.03 MiB/s 00:02 [------------------------------------] 100%
garuda-backgrounds-r15.cd07442-1-any 60.6 MiB 509 KiB/s 02:02 [------------------------------------] 100%
Total (5/5) 69.3 MiB 580 KiB/s 02:02 [------------------------------------] 100%
(5/5) checking keys in keyring [------------------------------------] 100%
(5/5) checking package integrity [------------------------------------] 100%
(5/5) loading package files [------------------------------------] 100%
(5/5) checking for file conflicts [------------------------------------] 100%
(5/5) checking available disk space [------------------------------------] 100%
==> root: 39
(1/5) upgrading filesystem [------------------------------------] 100%
warning: /etc/shells installed as /etc/shells.pacnew
(2/5) upgrading bash [------------------------------------] 100%
(3/5) upgrading garuda-backgrounds [------------------------------------] 100%
(4/5) upgrading grub [------------------------------------] 100%
:: To use the new features provided in this GRUB update, it is recommended
to install it to the MBR or UEFI. Due to potential configuration
incompatibilities, it is advised to run both, installation and generation
of configuration:
$ grub-install ...
$ grub-mkconfig -o /boot/grub/grub.cfg
(5/5) upgrading htop [------------------------------------] 100%
( 1/17) Enabling os-prober...
( 2/17) Adding Garuda specific configurations...
( 3/17) Creating system user accounts...
( 4/17) Applying kernel sysctl settings...
( 5/17) Creating temporary files...
( 6/17) Arming ConditionNeedsUpdate...
( 7/17) Foreign/AUR package notification
=> No foreign/AUR packages found.
( 8/17) Updating grub binary in EFI
The GRUB bootloader at EFI/Garuda is being updated!
Installing for x86_64-efi platform.
Installation finished. No error reported.
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-02-06 09:23:20 | @/.snapshots/39/snapshot | pre | pacman -Su |
Found snapshot: 2023-02-05 20:20:02 | @/.snapshots/38/snapshot | post | linux-headers |
Found snapshot: 2023-02-05 20:19:03 | @/.snapshots/37/snapshot | pre | pacman -S linux-headers |
Found snapshot: 2023-02-05 14:06:00 | @/.snapshots/36/snapshot | post | code garuda-backgrounds garuda-wallpapers perl-html-parser qt5-base |
Found snapshot: 2023-02-05 14:05:58 | @/.snapshots/35/snapshot | pre | pacman -Su |
Found snapshot: 2023-02-05 14:01:38 | @/.snapshots/34/snapshot | post | blas cblas dkms garuda-nvidia-config garuda-nvidia-prime-config gobject- |
Found snapshot: 2023-02-05 14:00:13 | @/.snapshots/33/snapshot | pre | pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman |
Found snapshot: 2023-02-05 13:59:25 | @/.snapshots/32/snapshot | post | nvidia |
Found snapshot: 2023-02-05 13:59:23 | @/.snapshots/31/snapshot | pre | pacman -R nvidia |
Found snapshot: 2023-02-05 12:55:28 | @/.snapshots/30/snapshot | post | linux nvidia |
Found snapshot: 2023-02-05 12:55:11 | @/.snapshots/29/snapshot | pre | pacman -S nvidia |
Found 11 snapshot(s)
Unmount /tmp/grub-btrfs.SAWYNYBCl1 .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
( 9/17) Orphaned package notification...
alsa-plugins 1:1.2.7.1-1
geocode-glib 3.26.4-2
js91 91.13.0-1
libvisual 0.4.0-8
mcfly 0.7.1-1
rest 0.8.1+r4+ge5ee6ef-1
shared-color-targets 0.1.7-4
zenity 3.44.0-1
(10/17) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/shells.pacnew
/etc/default/grub.pacnew
/etc/mkinitcpio.conf.pacnew
Please check and merge
(11/17) GRUB update after transactions...
Unmount /tmp/grub-btrfs.zxLfTzHUu0 .. Success
done
(12/17) Fix 'grub' and 'os-prober'
(13/17) Updating icon theme caches...
(14/17) Updating the info directory file...
(15/17) Updating the desktop file MIME type cache...
(16/17) Performing snapper post snapshots for the following configurations...
==> root: 40
(17/17) Syncing all file systems...
System updated! 🐧
Update notices:
The GRUB bootloader at /EFI/Garuda has been updated/reinstalled using 'grub-install'. If this looks correct, no further action has to be taken.
sudo pacman -S linux-zen linux-zen-headers nvidia-dkms:
warning: linux-zen-6.1.9.zen1-1 is up to date -- reinstalling
warning: linux-zen-headers-6.1.9.zen1-1 is up to date -- reinstalling
warning: nvidia-dkms-525.85.05-1 is up to date -- reinstalling
Packages (3) linux-zen-6.1.9.zen1-1 linux-zen-headers-6.1.9.zen1-1 nvidia-dkms-525.85.05-1
Total Installed Size: 387.48 MiB
Net Upgrade Size: 0.00 MiB
(3/3) checking keys in keyring [------------------------------------] 100%
(3/3) checking package integrity [------------------------------------] 100%
(3/3) loading package files [------------------------------------] 100%
(3/3) checking for file conflicts [------------------------------------] 100%
(3/3) checking available disk space [------------------------------------] 100%
(1/3) Performing snapper pre snapshots for the following configurations...
==> root: 41
(2/3) Saving Linux kernel modules...
(3/3) Remove upgraded DKMS modules
==> dkms remove --no-depmod nvidia/525.85.05 -k 6.1.9-arch1-1
==> dkms remove --no-depmod nvidia/525.85.05 -k 6.1.9-zen1-1-zen
(1/3) reinstalling linux-zen [------------------------------------] 100%
(2/3) reinstalling linux-zen-headers [------------------------------------] 100%
(3/3) reinstalling nvidia-dkms [------------------------------------] 100%
( 1/10) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.1.9-zen1-1-zen
+ test -e /usr/lib/modules/backup/6.1.9-zen1-1-zen
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/6.1.9-zen1-1-zen /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 2/10) Arming ConditionNeedsUpdate...
( 3/10) Updating module dependencies...
( 4/10) Install DKMS modules
==> dkms install --no-depmod nvidia/525.85.05 -k 6.1.9-arch1-1
==> dkms install --no-depmod nvidia/525.85.05 -k 6.1.9-zen1-1-zen
Module version 525.85.05 for nvidia.ko.zst
exactly matches what is already found in kernel 6.1.9-zen1-1-zen.
DKMS will not replace this module.
You may override by specifying --force.
Module version 525.85.05 for nvidia-uvm.ko.zst
Module version 525.85.05 for nvidia-modeset.ko.zst
Module version 525.85.05 for nvidia-drm.ko.zst
Module version 525.85.05 for nvidia-peermem.ko.zst
Error! Installation aborted.
==> WARNING: `dkms install --no-depmod nvidia/525.85.05 -k 6.1.9-zen1-1-zen' exited 6
==> depmod 6.1.9-arch1-1
( 5/10) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 6.1.9-arch1-1
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
loadkeys: Unable to open file: au: No such file or directory
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 6.1.9-zen1-1-zen
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
( 6/10) Foreign/AUR package notification
( 7/10) Orphaned package notification...
js91 91.13.0-1
libvisual 0.4.0-8
mcfly 0.7.1-1
zenity 3.44.0-1
( 8/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/shells.pacnew
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 42
(10/10) Syncing all file systems...
That looks good, be sure to reboot and then post a new garuda-inxi
jthro
February 5, 2023, 10:42pm
15
<pre><span style="color:#2A7BDE"><b>System:</b></span>
<span style="color:#2A7BDE"><b>Kernel:</b></span> 6.1.9-zen1-1-zen <span style="color:#2A7BDE"><b>arch:</b></span> x86_64 <span style="color:#2A7BDE"><b>bits:</b></span> 64 <span style="color:#2A7BDE"><b>compiler:</b></span> gcc <span style="color:#2A7BDE"><b>v:</b></span> 12.2.1
<span style="color:#2A7BDE"><b>parameters:</b></span> BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
loglevel=3 ibt=off
<span style="color:#2A7BDE"><b>Desktop:</b></span> GNOME <span style="color:#2A7BDE"><b>v:</b></span> 43.2 <span style="color:#2A7BDE"><b>tk:</b></span> GTK <span style="color:#2A7BDE"><b>v:</b></span> 3.24.36 <span style="color:#2A7BDE"><b>wm:</b></span> gnome-shell <span style="color:#2A7BDE"><b>dm:</b></span> GDM <span style="color:#2A7BDE"><b>v:</b></span> 43.0
<span style="color:#2A7BDE"><b>Distro:</b></span> Garuda Linux <span style="color:#2A7BDE"><b>base:</b></span> Arch Linux
<span style="color:#2A7BDE"><b>Machine:</b></span>
<span style="color:#2A7BDE"><b>Type:</b></span> Laptop <span style="color:#2A7BDE"><b>System:</b></span> Acer <span style="color:#2A7BDE"><b>product:</b></span> Aspire A715-51G <span style="color:#2A7BDE"><b>v:</b></span> V1.04
<span style="color:#2A7BDE"><b>serial:</b></span> <superuser required>
<span style="color:#2A7BDE"><b>Mobo:</b></span> ADL <span style="color:#2A7BDE"><b>model:</b></span> Metis_ADP <span style="color:#2A7BDE"><b>v:</b></span> V1.04 <span style="color:#2A7BDE"><b>serial:</b></span> <superuser required>
<span style="color:#2A7BDE"><b>UEFI:</b></span> INSYDE <span style="color:#2A7BDE"><b>v:</b></span> 1.04 <span style="color:#2A7BDE"><b>date:</b></span> 04/09/2022
<span style="color:#2A7BDE"><b>Battery:</b></span>
<span style="color:#2A7BDE"><b>ID-1:</b></span> BAT1 <span style="color:#2A7BDE"><b>charge:</b></span> 50.1 Wh (100.0%) <span style="color:#2A7BDE"><b>condition:</b></span> 50.1/47.8 Wh (104.8%)
<span style="color:#2A7BDE"><b>volts:</b></span> 12.9 <span style="color:#2A7BDE"><b>min:</b></span> 11.2 <span style="color:#2A7BDE"><b>model:</b></span> LGC AP18C8K <span style="color:#2A7BDE"><b>type:</b></span> Li-ion <span style="color:#2A7BDE"><b>serial:</b></span> <filter>
<span style="color:#2A7BDE"><b>status:</b></span> full
<span style="color:#2A7BDE"><b>CPU:</b></span>
<span style="color:#2A7BDE"><b>Info:</b></span> <span style="color:#2A7BDE"><b>model:</b></span> 12th Gen Intel Core i5-1240P <span style="color:#2A7BDE"><b>bits:</b></span> 64 <span style="color:#2A7BDE"><b>type:</b></span> MST AMCP
<span style="color:#2A7BDE"><b>arch:</b></span> Alder Lake <span style="color:#2A7BDE"><b>level:</b></span> v3 <span style="color:#2A7BDE"><b>note:</b></span> check <span style="color:#2A7BDE"><b>built:</b></span> 2021+
<span style="color:#2A7BDE"><b>process:</b></span> Intel 7 (10nm ESF) <span style="color:#2A7BDE"><b>family:</b></span> 6 <span style="color:#2A7BDE"><b>model-id:</b></span> 0x9A (154) <span style="color:#2A7BDE"><b>stepping:</b></span> 3
<span style="color:#2A7BDE"><b>microcode:</b></span> 0x424
<span style="color:#2A7BDE"><b>Topology:</b></span> <span style="color:#2A7BDE"><b>cpus:</b></span> 1x <span style="color:#2A7BDE"><b>cores:</b></span> 12 <span style="color:#2A7BDE"><b>mt:</b></span> 4 <span style="color:#2A7BDE"><b>tpc:</b></span> 2 <span style="color:#2A7BDE"><b>st:</b></span> 8 <span style="color:#2A7BDE"><b>threads:</b></span> 16 <span style="color:#2A7BDE"><b>smt:</b></span> enabled
<span style="color:#2A7BDE"><b>cache:</b></span> <span style="color:#2A7BDE"><b>L1:</b></span> 1.1 MiB <span style="color:#2A7BDE"><b>desc:</b></span> d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
<span style="color:#2A7BDE"><b>L2:</b></span> 9 MiB <span style="color:#2A7BDE"><b>desc:</b></span> 4x1.2 MiB, 2x2 MiB <span style="color:#2A7BDE"><b>L3:</b></span> 12 MiB <span style="color:#2A7BDE"><b>desc:</b></span> 1x12 MiB
<span style="color:#2A7BDE"><b>Speed (MHz):</b></span> <span style="color:#2A7BDE"><b>avg:</b></span> 1815 <span style="color:#2A7BDE"><b>high:</b></span> 2100 <span style="color:#2A7BDE"><b>min/max:</b></span> 400/4400:3300 <span style="color:#2A7BDE"><b>scaling:</b></span>
<span style="color:#2A7BDE"><b>driver:</b></span> intel_pstate <span style="color:#2A7BDE"><b>governor:</b></span> powersave <span style="color:#2A7BDE"><b>cores:</b></span> <span style="color:#2A7BDE"><b>1:</b></span> 600 <span style="color:#2A7BDE"><b>2:</b></span> 2100 <span style="color:#2A7BDE"><b>3:</b></span> 2100
<span style="color:#2A7BDE"><b>4:</b></span> 2100 <span style="color:#2A7BDE"><b>5:</b></span> 560 <span style="color:#2A7BDE"><b>6:</b></span> 2100 <span style="color:#2A7BDE"><b>7:</b></span> 582 <span style="color:#2A7BDE"><b>8:</b></span> 2100 <span style="color:#2A7BDE"><b>9:</b></span> 2100 <span style="color:#2A7BDE"><b>10:</b></span> 2100 <span style="color:#2A7BDE"><b>11:</b></span> 2100 <span style="color:#2A7BDE"><b>12:</b></span> 2100
<span style="color:#2A7BDE"><b>13:</b></span> 2100 <span style="color:#2A7BDE"><b>14:</b></span> 2100 <span style="color:#2A7BDE"><b>15:</b></span> 2100 <span style="color:#2A7BDE"><b>16:</b></span> 2100 <span style="color:#2A7BDE"><b>bogomips:</b></span> 67584
<span style="color:#2A7BDE"><b>Flags:</b></span> avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
<span style="color:#2A7BDE"><b>Vulnerabilities:</b></span> <filter>
<span style="color:#2A7BDE"><b>Graphics:</b></span>
<span style="color:#2A7BDE"><b>Device-1:</b></span> Intel Alder Lake-P Integrated Graphics
<span style="color:#2A7BDE"><b>vendor:</b></span> Acer Incorporated ALI <span style="color:#2A7BDE"><b>driver:</b></span> i915 <span style="color:#2A7BDE"><b>v:</b></span> kernel <span style="color:#2A7BDE"><b>arch:</b></span> Gen-12.2
<span style="color:#2A7BDE"><b>process:</b></span> Intel 10nm <span style="color:#2A7BDE"><b>built:</b></span> 2021-22+ <span style="color:#2A7BDE"><b>ports:</b></span> <span style="color:#2A7BDE"><b>active:</b></span> HDMI-A-1,eDP-1
<span style="color:#2A7BDE"><b>empty:</b></span> DP-1,DP-2 <span style="color:#2A7BDE"><b>bus-ID:</b></span> 0000:00:02.0 <span style="color:#2A7BDE"><b>chip-ID:</b></span> 8086:4626 <span style="color:#2A7BDE"><b>class-ID:</b></span> 0300
<span style="color:#2A7BDE"><b>Device-2:</b></span> NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
<span style="color:#2A7BDE"><b>vendor:</b></span> Acer Incorporated ALI <span style="color:#2A7BDE"><b>driver:</b></span> nvidia <span style="color:#2A7BDE"><b>v:</b></span> 525.85.05
<span style="color:#2A7BDE"><b>alternate:</b></span> nouveau,nvidia_drm <span style="color:#2A7BDE"><b>non-free:</b></span> 525.xx+
<span style="color:#2A7BDE"><b>status:</b></span> current (as of 2022-12) <span style="color:#2A7BDE"><b>arch:</b></span> Turing <span style="color:#2A7BDE"><b>code:</b></span> TUxxx
<span style="color:#2A7BDE"><b>process:</b></span> TSMC 12nm FF <span style="color:#2A7BDE"><b>built:</b></span> 2018-22 <span style="color:#2A7BDE"><b>bus-ID:</b></span> 0000:01:00.0
<span style="color:#2A7BDE"><b>chip-ID:</b></span> 10de:1f9d <span style="color:#2A7BDE"><b>class-ID:</b></span> 0302
<span style="color:#2A7BDE"><b>Device-3:</b></span> Quanta ACER HD User Facing <span style="color:#2A7BDE"><b>type:</b></span> USB <span style="color:#2A7BDE"><b>driver:</b></span> N/A <span style="color:#2A7BDE"><b>bus-ID:</b></span> 3-6:6
<span style="color:#2A7BDE"><b>chip-ID:</b></span> 0408:4033 <span style="color:#2A7BDE"><b>class-ID:</b></span> fe01 <span style="color:#2A7BDE"><b>serial:</b></span> <filter>
<span style="color:#2A7BDE"><b>Display:</b></span> x11 <span style="color:#2A7BDE"><b>server:</b></span> X.Org <span style="color:#2A7BDE"><b>v:</b></span> 21.1.6 <span style="color:#2A7BDE"><b>with:</b></span> Xwayland <span style="color:#2A7BDE"><b>v:</b></span> 22.1.7
<span style="color:#2A7BDE"><b>compositor:</b></span> gnome-shell <span style="color:#2A7BDE"><b>driver:</b></span> <span style="color:#2A7BDE"><b>X:</b></span> <span style="color:#2A7BDE"><b>loaded:</b></span> modesetting,nvidia
<span style="color:#2A7BDE"><b>unloaded:</b></span> nouveau <span style="color:#2A7BDE"><b>alternate:</b></span> fbdev,intel,nv,vesa <span style="color:#2A7BDE"><b>dri:</b></span> iris <span style="color:#2A7BDE"><b>gpu:</b></span> i915
<span style="color:#2A7BDE"><b>display-ID:</b></span> :1 <span style="color:#2A7BDE"><b>screens:</b></span> 1
<span style="color:#2A7BDE"><b>Screen-1:</b></span> 0 <span style="color:#2A7BDE"><b>s-res:</b></span> 3840x1080 <span style="color:#2A7BDE"><b>s-dpi:</b></span> 96 <span style="color:#2A7BDE"><b>s-size:</b></span> 1016x285mm (40.00x11.22")
<span style="color:#2A7BDE"><b>s-diag:</b></span> 1055mm (41.54")
<span style="color:#2A7BDE"><b>Monitor-1:</b></span> HDMI-A-1 <span style="color:#2A7BDE"><b>mapped:</b></span> HDMI-1 <span style="color:#2A7BDE"><b>pos:</b></span> primary,right
<span style="color:#2A7BDE"><b>model:</b></span> Samsung S22B350 <span style="color:#2A7BDE"><b>serial:</b></span> <filter> <span style="color:#2A7BDE"><b>built:</b></span> 2012 <span style="color:#2A7BDE"><b>res:</b></span> 1920x1080 <span style="color:#2A7BDE"><b>hz:</b></span> 60
<span style="color:#2A7BDE"><b>dpi:</b></span> 102 <span style="color:#2A7BDE"><b>gamma:</b></span> 1.2 <span style="color:#2A7BDE"><b>size:</b></span> 477x268mm (18.78x10.55") <span style="color:#2A7BDE"><b>diag:</b></span> 547mm (21.5")
<span style="color:#2A7BDE"><b>ratio:</b></span> 16:9 <span style="color:#2A7BDE"><b>modes:</b></span> <span style="color:#2A7BDE"><b>max:</b></span> 1920x1080 <span style="color:#2A7BDE"><b>min:</b></span> 720x400
<span style="color:#2A7BDE"><b>Monitor-2:</b></span> eDP-1 <span style="color:#2A7BDE"><b>pos:</b></span> left <span style="color:#2A7BDE"><b>model:</b></span> Najing CEC Panda 0x004d <span style="color:#2A7BDE"><b>built:</b></span> 2019
<span style="color:#2A7BDE"><b>res:</b></span> 1920x1080 <span style="color:#2A7BDE"><b>dpi:</b></span> 142 <span style="color:#2A7BDE"><b>gamma:</b></span> 1.2 <span style="color:#2A7BDE"><b>size:</b></span> 344x194mm (13.54x7.64")
<span style="color:#2A7BDE"><b>diag:</b></span> 395mm (15.5") <span style="color:#2A7BDE"><b>ratio:</b></span> 16:9 <span style="color:#2A7BDE"><b>modes:</b></span> 1920x1080
<span style="color:#2A7BDE"><b>API:</b></span> OpenGL <span style="color:#2A7BDE"><b>Message:</b></span> Unable to show GL data. Required tool glxinfo
missing.
<span style="color:#2A7BDE"><b>Audio:</b></span>
<span style="color:#2A7BDE"><b>Device-1:</b></span> Intel Alder Lake PCH-P High Definition Audio
<span style="color:#2A7BDE"><b>vendor:</b></span> Acer Incorporated ALI <span style="color:#2A7BDE"><b>driver:</b></span> sof-audio-pci-intel-tgl
<span style="color:#2A7BDE"><b>alternate:</b></span> snd_hda_intel,snd_sof_pci_intel_tgl <span style="color:#2A7BDE"><b>bus-ID:</b></span> 3-1.3:9
<span style="color:#2A7BDE"><b>chip-ID:</b></span> 2516:0131 <span style="color:#2A7BDE"><b>bus-ID:</b></span> 0000:00:1f.3 <span style="color:#2A7BDE"><b>chip-ID:</b></span> 8086:51c8 <span style="color:#2A7BDE"><b>class-ID:</b></span> 0300
<span style="color:#2A7BDE"><b>class-ID:</b></span> 0401
<span style="color:#2A7BDE"><b>Device-2:</b></span> Cooler Master CH321 <span style="color:#2A7BDE"><b>type:</b></span> USB
<span style="color:#2A7BDE"><b>driver:</b></span> hid-generic,snd-usb-audio,usbhid
<span style="color:#2A7BDE"><b>Device-3:</b></span> Texas Instruments PCM2902 Audio Codec <span style="color:#2A7BDE"><b>type:</b></span> USB
<span style="color:#2A7BDE"><b>driver:</b></span> hid-generic,snd-usb-audio,usbhid <span style="color:#2A7BDE"><b>bus-ID:</b></span> 3-1.4:4 <span style="color:#2A7BDE"><b>chip-ID:</b></span> 08bb:2902
<span style="color:#2A7BDE"><b>Sound API:</b></span> ALSA <span style="color:#2A7BDE"><b>v:</b></span> k6.1.9-zen1-1-zen <span style="color:#2A7BDE"><b>running:</b></span> yes
<span style="color:#2A7BDE"><b>Sound Server-1:</b></span> PulseAudio <span style="color:#2A7BDE"><b>v:</b></span> 16.1 <span style="color:#2A7BDE"><b>running:</b></span> no
<span style="color:#2A7BDE"><b>Sound Server-2:</b></span> PipeWire <span style="color:#2A7BDE"><b>v:</b></span> 0.3.65 <span style="color:#2A7BDE"><b>running:</b></span> yes
<span style="color:#2A7BDE"><b>Network:</b></span>
<span style="color:#2A7BDE"><b>Device-1:</b></span> MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
<span style="color:#2A7BDE"><b>vendor:</b></span> Lite-On <span style="color:#2A7BDE"><b>driver:</b></span> mt7921e <span style="color:#2A7BDE"><b>v:</b></span> kernel <span style="color:#2A7BDE"><b>bus-ID:</b></span> 0000:3d:00.0
<span style="color:#2A7BDE"><b>chip-ID:</b></span> 14c3:7961 <span style="color:#2A7BDE"><b>class-ID:</b></span> 0280
<span style="color:#2A7BDE"><b>IF:</b></span> wlp61s0 <span style="color:#2A7BDE"><b>state:</b></span> up <span style="color:#2A7BDE"><b>mac:</b></span> <filter>
<span style="color:#2A7BDE"><b>Device-2:</b></span> Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
<span style="color:#2A7BDE"><b>vendor:</b></span> Acer Incorporated ALI <span style="color:#2A7BDE"><b>driver:</b></span> r8169 <span style="color:#2A7BDE"><b>v:</b></span> kernel <span style="color:#2A7BDE"><b>port:</b></span> 3000
<span style="color:#2A7BDE"><b>bus-ID:</b></span> 0000:3e:00.0 <span style="color:#2A7BDE"><b>chip-ID:</b></span> 10ec:8168 <span style="color:#2A7BDE"><b>class-ID:</b></span> 0200
<span style="color:#2A7BDE"><b>IF:</b></span> enp62s0 <span style="color:#2A7BDE"><b>state:</b></span> down <span style="color:#2A7BDE"><b>mac:</b></span> <filter>
<span style="color:#2A7BDE"><b>Bluetooth:</b></span>
<span style="color:#2A7BDE"><b>Device-1:</b></span> Lite-On Wireless_Device <span style="color:#2A7BDE"><b>type:</b></span> USB <span style="color:#2A7BDE"><b>driver:</b></span> btusb <span style="color:#2A7BDE"><b>v:</b></span> 0.8
<span style="color:#2A7BDE"><b>bus-ID:</b></span> 3-10:8 <span style="color:#2A7BDE"><b>chip-ID:</b></span> 04ca:3802 <span style="color:#2A7BDE"><b>class-ID:</b></span> e001 <span style="color:#2A7BDE"><b>serial:</b></span> <filter>
<span style="color:#2A7BDE"><b>Report:</b></span> bt-adapter <span style="color:#2A7BDE"><b>ID:</b></span> hci0 <span style="color:#2A7BDE"><b>rfk-id:</b></span> 2 <span style="color:#2A7BDE"><b>state:</b></span> up <span style="color:#2A7BDE"><b>address:</b></span> <filter>
<span style="color:#2A7BDE"><b>RAID:</b></span>
<span style="color:#2A7BDE"><b>Hardware-1:</b></span> Intel Volume Management Device NVMe RAID Controller <span style="color:#2A7BDE"><b>driver:</b></span> vmd
<span style="color:#2A7BDE"><b>v:</b></span> 0.6 <span style="color:#2A7BDE"><b>port:</b></span> N/A <span style="color:#2A7BDE"><b>bus-ID:</b></span> 0000:00:0e.0 <span style="color:#2A7BDE"><b>chip-ID:</b></span> 8086:467f <span style="color:#2A7BDE"><b>rev:</b></span> <span style="color:#2A7BDE"><b>class-ID:</b></span> 0104
<span style="color:#2A7BDE"><b>Drives:</b></span>
<span style="color:#2A7BDE"><b>Local Storage:</b></span> <span style="color:#2A7BDE"><b>total:</b></span> 476.94 GiB <span style="color:#2A7BDE"><b>used:</b></span> 15.06 GiB (3.2%)
<span style="color:#2A7BDE"><b>SMART Message:</b></span> Required tool smartctl not installed. Check --recommends
<span style="color:#2A7BDE"><b>ID-1:</b></span> /dev/nvme0n1 <span style="color:#2A7BDE"><b>maj-min:</b></span> 259:0 <span style="color:#2A7BDE"><b>vendor:</b></span> Western Digital <span style="color:#2A7BDE"><b>model:</b></span> WD PC
SN740 SDDQNQD-512G-1014 <span style="color:#2A7BDE"><b>size:</b></span> 476.94 GiB <span style="color:#2A7BDE"><b>block-size:</b></span> <span style="color:#2A7BDE"><b>physical:</b></span> 512 B
<span style="color:#2A7BDE"><b>logical:</b></span> 512 B <span style="color:#2A7BDE"><b>speed:</b></span> 63.2 Gb/s <span style="color:#2A7BDE"><b>lanes:</b></span> 4 <span style="color:#2A7BDE"><b>type:</b></span> SSD <span style="color:#2A7BDE"><b>serial:</b></span> <filter>
<span style="color:#2A7BDE"><b>rev:</b></span> 73101100 <span style="color:#2A7BDE"><b>temp:</b></span> 46.9 C <span style="color:#2A7BDE"><b>scheme:</b></span> GPT
<span style="color:#2A7BDE"><b>Partition:</b></span>
<span style="color:#2A7BDE"><b>ID-1:</b></span> / <span style="color:#2A7BDE"><b>raw-size:</b></span> 229.49 GiB <span style="color:#2A7BDE"><b>size:</b></span> 229.49 GiB (100.00%)
<span style="color:#2A7BDE"><b>used:</b></span> 15.01 GiB (6.5%) <span style="color:#2A7BDE"><b>fs:</b></span> btrfs <span style="color:#2A7BDE"><b>dev:</b></span> /dev/nvme0n1p5 <span style="color:#2A7BDE"><b>maj-min:</b></span> 259:5
<span style="color:#2A7BDE"><b>ID-2:</b></span> /boot/efi <span style="color:#2A7BDE"><b>raw-size:</b></span> 260 MiB <span style="color:#2A7BDE"><b>size:</b></span> 256 MiB (98.46%)
<span style="color:#2A7BDE"><b>used:</b></span> 58.8 MiB (23.0%) <span style="color:#2A7BDE"><b>fs:</b></span> vfat <span style="color:#2A7BDE"><b>dev:</b></span> /dev/nvme0n1p1 <span style="color:#2A7BDE"><b>maj-min:</b></span> 259:1
<span style="color:#2A7BDE"><b>ID-3:</b></span> /home <span style="color:#2A7BDE"><b>raw-size:</b></span> 229.49 GiB <span style="color:#2A7BDE"><b>size:</b></span> 229.49 GiB (100.00%)
<span style="color:#2A7BDE"><b>ID-4:</b></span> /var/log <span style="color:#2A7BDE"><b>raw-size:</b></span> 229.49 GiB <span style="color:#2A7BDE"><b>size:</b></span> 229.49 GiB (100.00%)
<span style="color:#2A7BDE"><b>ID-5:</b></span> /var/tmp <span style="color:#2A7BDE"><b>raw-size:</b></span> 229.49 GiB <span style="color:#2A7BDE"><b>size:</b></span> 229.49 GiB (100.00%)
<span style="color:#2A7BDE"><b>Swap:</b></span>
<span style="color:#2A7BDE"><b>Kernel:</b></span> <span style="color:#2A7BDE"><b>swappiness:</b></span> 133 (default 60) <span style="color:#2A7BDE"><b>cache-pressure:</b></span> 100 (default)
<span style="color:#2A7BDE"><b>ID-1:</b></span> swap-1 <span style="color:#2A7BDE"><b>type:</b></span> zram <span style="color:#2A7BDE"><b>size:</b></span> 15.33 GiB <span style="color:#2A7BDE"><b>used:</b></span> 0 KiB (0.0%) <span style="color:#2A7BDE"><b>priority:</b></span> 100
<span style="color:#2A7BDE"><b>dev:</b></span> /dev/zram0
<span style="color:#2A7BDE"><b>Sensors:</b></span>
<span style="color:#2A7BDE"><b>System Temperatures:</b></span> <span style="color:#2A7BDE"><b>cpu:</b></span> 39.0 C <span style="color:#2A7BDE"><b>mobo:</b></span> N/A
<span style="color:#2A7BDE"><b>Fan Speeds (RPM):</b></span> N/A
<span style="color:#2A7BDE"><b>Processes:</b></span> 363 <span style="color:#2A7BDE"><b>Uptime:</b></span> 0m <span style="color:#2A7BDE"><b>wakeups:</b></span> 1 <span style="color:#2A7BDE"><b>Memory:</b></span> 15.33 GiB
<span style="color:#2A7BDE"><b>used:</b></span> 2.64 GiB (17.2%) <span style="color:#2A7BDE"><b>Init:</b></span> systemd <span style="color:#2A7BDE"><b>v:</b></span> 252 <span style="color:#2A7BDE"><b>default:</b></span> graphical
<span style="color:#2A7BDE"><b>tool:</b></span> systemctl <span style="color:#2A7BDE"><b>Compilers:</b></span> <span style="color:#2A7BDE"><b>gcc:</b></span> 12.2.1 <span style="color:#2A7BDE"><b>Packages:</b></span> <span style="color:#2A7BDE"><b>pm:</b></span> pacman <span style="color:#2A7BDE"><b>pkgs:</b></span> 1173
<span style="color:#2A7BDE"><b>libs:</b></span> 355 <span style="color:#2A7BDE"><b>tools:</b></span> pamac,paru <span style="color:#2A7BDE"><b>Shell:</b></span> fish <span style="color:#2A7BDE"><b>v:</b></span> 3.6.0 <span style="color:#2A7BDE"><b>default:</b></span> Bash <span style="color:#2A7BDE"><b>v:</b></span> 5.1.16
<span style="color:#2A7BDE"><b>running-in:</b></span> gnome-terminal <span style="color:#2A7BDE"><b>inxi:</b></span> 3.3.24
<span style="color:#2A7BDE"><b>Garuda (2.6.14-1):</b></span>
<span style="color:#2A7BDE"><b> System install date:</b></span> 2023-02-04
<span style="color:#2A7BDE"><b> Last full system update:</b></span> 2023-02-06
<span style="color:#2A7BDE"><b> Is partially upgraded: </b></span> No
<span style="color:#2A7BDE"><b> Relevant software: </b></span> snapper NetworkManager mkinitcpio nvidia-dkms
<span style="color:#2A7BDE"><b> Windows dual boot: </b></span> Probably (Run as root to verify)
<span style="color:#2A7BDE"><b> Failed units: </b></span> systemd-vconsole-setup.service
</pre>
Nice, you got the driver fixed. Do you notice any improvement with the screen issue?
jthro
February 5, 2023, 10:47pm
17
Nope. It is still wobbling.
Can you describe the issue another way? It's unclear what is happening.
A logical next step would be to test other cables.
jthro
February 5, 2023, 10:54pm
19
Ok so on the far left side of my monitor nothing is wrong. But the effect gets progressively worse the further to the right I look. Anywhere where there are two different colors adjacent to each other it "wobbles" from left to right.
It's especially obvious along vertical lines, it looks like heat haze on a hot day.
Unfortunately I cannot upload a video.
SGS
February 6, 2023, 2:03am
20
Hi,
apparently you didn’t notice that I formatted your first posts, please change your following posts with terminal output as follows.
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text in the view. Move the mouse pointer over it in the upper right corner.
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
jthro
February 6, 2023, 4:49am
21
Ok sorry, will do in future
