Hello everyone,
Just installed Garuda alongside windows (replacing manjaro), to hopefully get a bit more into linux as a main OS...
I have a dual-GPU (2x asus GTX1080ti) setup with 4 monitors. The problem is that monitors that are connected to the second GPU are detected in display settings, but no signal is output to them. Checking the "active" doesn't do much besides letting the screen to scroll to the area where the display should be when the cursor moves offscreen.
garuda-inxi output:
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e14018aa-7aaa-4ccf-a346-18848002dd77 rw rootflags=subvol=@
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z370-E GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 3004 date: 07/12/2021
ID-1: hidpp_battery_1 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: N/A
ID-2: hidpp_battery_3 charge: 100% condition: N/A volts: 4.2 min: N/A
Info: model: Intel Core i7-8700K socket: LGA1151 bits: 64 type: MT MCP
arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3883 high: 4801 min/max: 800/4900 base/boost: 3700/8300
scaling: driver: intel_pstate governor: performance volts: 1.1 V
ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 4800 4: 3700 5: 3700 6: 3700
7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 4801 bogomips: 88796
vulnerable
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia
v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b06 class-ID: 0300
Device-2: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.0
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia display-ID: :0
Screen-1: 0 s-res: 5120x2520 s-dpi: 107 s-size: 1216x598mm (47.87x23.54")
s-diag: 1355mm (53.35")
Monitor-1: DP-1-2 size-res: N/A modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-3: HDMI-0 pos: top-right res: 1920x1080 hz: 60 dpi: 69
size: 708x398mm (27.87x15.67") diag: 812mm (31.98") modes: N/A
Monitor-4: HDMI-1 pos: primary,bottom-r res: 2560x1440 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-6.3.4.1:14 bus-ID: 00:1f.3
chip-ID: 0951:171d chip-ID: 8086:a2f0 class-ID: 0300 serial: <filter>
Device-2: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-3: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 02:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-4: Kingston HyperX QuadCast S type: USB
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:b822
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 3.18 TiB used: 28.43 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7
temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 2y 252d 13h cycles: 337
read-units: 310,639,626 [159 TB] written-units: 71,132,484 [36.4 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4y 183d 7h cycles: 336
written: 5.68 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX002-2DV164
family: FireCuda 3.5 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: CC41 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4y 182d 21h cycles: 336
read: 159 TiB written: 5.39 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 95.91 GiB size: 95.91 GiB (100.00%) used: 27.22 GiB
(28.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 199.62 GiB size: 199.62 GiB (100.00%) used: 130.2
MiB (0.1%) fs: btrfs block-size: 4096 B dev: /dev/sdb3 maj-min: 8:19
ID-4: /opt raw-size: 200.32 GiB size: 200.32 GiB (100.00%) used: 1.08 GiB
(0.5%) fs: btrfs block-size: 4096 B dev: /dev/sda3 maj-min: 8:3
ID-5: /var/log raw-size: 95.91 GiB size: 95.91 GiB (100.00%) used: 27.22
GiB (28.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-6: /var/tmp raw-size: 95.91 GiB size: 95.91 GiB (100.00%) used: 27.22
maj-min: 259:7
ID-1: swap-1 type: zram size: 31.28 GiB used: 1.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 31.3 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 343 Uptime: 1h 16m wakeups: 16 Memory: 31.28 GiB used: 5.06 GiB
(16.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2080
libs: 563 tools: octopi,pamac,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-10-13
Last full system update: 2022-10-13
Windows dual boot: Yes
This setup did work on Manjaro, I don't remember if I got it to work manually or if it worked after merely updating the drivers.
I feel like there is something really simple I'm missing, but I'm failing to find any relevant information by searching around here, arch forums or search engines.
I auto-installed the proprietary drivers with the mhwd, which was probably done by the installer/updater anyway after reboot it didn't change anything.
