KDE System Settings Crash - SDL_AddAtomicInt Missing in SDL3
Opening KDE System Settings and navigating to the Controller section causes the application to crash. Running systemsettings from the terminal shows the error. I first noticed the error when i tried launching stremio but it refused to open. Opening stremio from the terminal shows the same error. I thought it was a stremio specific issue at first so i ignored it and installed the web app version. Since it is happening elsewhere too I figured it was a system issue.
Troubleshooting Steps Taken
Rebooted the system
Verified SDL3 is installed and up to date
Searched online and in the Garuda forums but found no direct solution
System Information (garuda-inxi)
Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3ee75408-4d82-4aee-8e9c-3ebe1a12155a rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_x11 tools: avail: xss-lock,xtrlock vt: 2 dm: 1: LightDM v: 1.32.0
note: stopped 2: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE AX V2 v: x.x
Megatrends LLC. v: FF date: 03/22/2024
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Speed (MHz): avg: 1752 min/max: 550/4851 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1752 2: 1752 3: 1752
4: 1752 5: 1752 6: 1752 7: 1752 8: 1752 9: 1752 10: 1752 11: 1752 12: 1752
13: 1752 14: 1752 15: 1752 16: 1752 bogomips: 121376
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Sapphire driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2,
HDMI-A-1, Writeback-1 bus-ID: 08:00.0 chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
Monitor-1: DP-3 mapped: DisplayPort-2 model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2023 res: mode: 1920x1080 hz: 144 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
navi22 LLVM 19.1.7 DRM 3.59 6.13.2-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
x11: xdriinfo, xdpyinfo, xprop, xrandr
bus-ID: 08:00.1 chip-ID: 1002:ab28 class-ID: 0403
lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 08bb:2902 class-ID: 0300
Device-4: FiiO KA13 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 2972:0062
class-ID: 0102
API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0608
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0e8d:0608
Local Storage: total: 2.73 TiB used: 1.17 TiB (42.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR411 temp: 30.9 C
model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
used: 760.48 GiB (81.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 859.2 MiB (2.7%)
System Temperatures: cpu: 44.2 C mobo: 29.0 C gpu: amdgpu temp: 34.0 C
mem: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 838
Memory: total: 32 GiB available: 31.26 GiB used: 9.55 GiB (30.5%)
Processes: 411 Power: uptime: 1h 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2413 libs: 620 tools: paru,yay Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: Zsh v: 5.9
running-in: yakuake inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2023-11-14
Last full system update: 2025-02-21 ↻
Output of pacman -Qs sdl if it helps
local/lib32-sdl12-compat 1.2.68-2
SDL 1.2 runtime compatibility library using SDL 2.0
local/lib32-sdl2-compat 2.32.50-1
An SDL2 compatibility layer that uses SDL3 behind the scenes - 32-bit
local/lib32-sdl2_image 2.8.4-1
A simple library to load images of various formats as SDL surfaces
local/lib32-sdl2_mixer 2.8.0-1
A simple multi-channel audio mixer
local/lib32-sdl2_ttf 2.24.0-1
Library that allows you to use TrueType fonts in your SDL applications (Version 2) (32-bit)
local/lib32-sdl3 3.2.4-1
A library for portable low-level access to a video framebuffer, audio output, mouse, and keyboard (Version 3) - 32-bit
local/lib32-sdl_image 1.2.12-9
A simple library to load images of various formats as SDL surfaces (32-bit)
local/lib32-sdl_mixer 1.2.12-6
local/lib32-sdl_ttf 2.0.11-9
A library that allows you to use TrueType fonts in your SDL applications (32-bit)
local/qemu-audio-sdl 9.2.0-2
QEMU SDL audio driver
local/qemu-ui-sdl 9.2.0-2
QEMU SDL UI driver
local/sdl12-compat 1.2.68-2
local/sdl2-compat 2.32.50-1
local/sdl2_image 2.8.5-1
A simple library to load images of various formats as SDL surfaces (Version 2)
local/sdl2_mixer 2.8.1-1
A simple multi-channel audio mixer (Version 2)
local/sdl2_ttf 2.24.0-1
A library that allows you to use TrueType fonts in your SDL applications (Version 2)
local/sdl3 1:3.0.0.r5890.gd6ad28a-1
Simple Directmedia Layer (Version 3 Pre-Release, Updated weekly)
local/sdl_image 1.2.12-9
local/sdl_mixer 1.2.12-12
local/sdl_ttf 2.0.11-7
Would appreciate any guidance on resolving this issue. Thanks!
