SDDM Settings not setting
Hello!
I have been fighting tooth and nail to get the SDDM to reflect the Plasma settings. I have a duo monitor set up and I have taken the following steps to try to fix the issue.
  1. Disable the second monitor in the Display Settings
  2. Return to the Themes, SDDM page
  3. Apply Plasma Settings
  4. Re-select the SDDM (Default Dragonized Sweet)
  5. Apply changes one more again
  6. Restart PC
That did not work, so I checked the sddm.conf in etc and it was blank with no changes made. I then retrieved an example document and attempted to re-try the steps above with no success.
  Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=e1cb13cc-74c5-4ead-9101-8936521fcc05 rw rootflags=subvol=@
    quiet loglevel=3 ipv6.disable=1 ibt=off
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI) v: Rev X.0x
    UEFI: American Megatrends v: 4601 date: 07/28/2023
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3325 high: 4205 min/max: 2200/5361 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4202 2: 2200
    3: 4198 4: 4199 5: 4199 6: 4200 7: 2200 8: 4202 9: 4200 10: 2200 11: 4205
    12: 2200 13: 2200 14: 2200 15: 2200 16: 4199 bogomips: 134412
  Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
    empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 0e:00.0 chip-ID: 1002:73a5
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
  Screen-1: 0 s-res: 3640x1920 s-dpi: 96 s-size: 963x508mm (37.91x20.00")
    s-diag: 1089mm (42.87")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-r
    model: LG (GoldStar) 27GL850 serial: <filter> built: 2020 res: 2560x1440
    hz: 144 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x350
  Monitor-2: DP-3 mapped: DisplayPort-2 pos: top-left
    model: ViewSonic VG2753 Series serial: <filter> built: 2018 res: 1080x1920
    hz: 60 dpi: 82 gamma: 1.2 size: 336x598mm (13.23x23.54") diag: 686mm (27")
    ratio: 16:9 modes: max: 1920x1080 min: 720x240
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
    navi21 LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:73a5
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 24.1.4-arch1.2
    device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:ab28
    bus-ID: 11:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Creative Pebble V3 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2
    chip-ID: 041e:3272 class-ID: 0300 serial: <filter>
  Device-4: HP HyperX Cloud Alpha Wireless
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.3:3 chip-ID: 03f0:098d
  API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:4 chip-ID: 8087:0029
  Local Storage: total: 2.3 TiB used: 204.16 GiB (8.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 27.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Kingston model: SA2000M8500G
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42102 temp: 27.9 C
  ID-3: /dev/nvme2n1 maj-min: 259:4 vendor: Western Digital
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111110WD temp: 30.9 C scheme: GPT
    used: 204.16 GiB (21.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 31.0 C mobo: 27.0 C gpu: amdgpu temp: 42.0 C
    mem: 42.0 C
  Fan Speeds (rpm): cpu: 1105 gpu: amdgpu fan: 0
  Memory: total: 32 GiB available: 31.25 GiB used: 5.68 GiB (18.2%)
  Processes: 392 Power: uptime: 54m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1558 libs: 478 tools: octopi,paru Compilers:
    clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
  System install date:     2024-07-26
  Last full system update: 2024-07-27
