old mice with existing setups are dead when it comes to supergaming, another problem is also web scrolling, the default setup is too slow. As a layman and the rest of children interested in colored icons, he may not be able to dig up the configuration files, and not one would like to have faster settings at hand.
Is it not possible to adjust movement and scrolling speed in the DE's mouse settings?
Yes, @Mordex47 we are all missing your garuda-inxi
Unfortunately, my translation programme fails in parts of your question.
this is name file ?
maybe it's advance leanguage
Please edit your last post, no need to post like in a chat room.
what is it ?
From the template you delete.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
do you won help me ?
@Mordex47 if English is difficult, post in a language that is easier for you.
You need to type this command into your terminal and paste the output into the forum so we can see it.
I think someone should make a YT video or at least a series of pictures,
like those assembly instructions for furniture from Sweden.
I think we need the same sort of "intelligence" test the Arch Forums use.
Calling Alan Turing
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=90f91cf3-084c-41ef-a5c8-71d8fd2a9a28 rw rootflags=subvol=@
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 065C71 v: X02 serial: <filter> UEFI-[Legacy]: Dell
v: 1.15.0 date: 08/30/2021
ID-1: BAT0 charge: 68.7 Wh (100.0%) condition: 68.7/74.0 Wh (92.8%)
volts: 12.7 min: 11.4 model: SMP DELL 71JF452 type: Li-poly
serial: <filter> status: full
Info: model: Intel Core i7-7700HQ socket: U3E1 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1047 high: 1100 min/max: 800/3800 base/boost: 2700/2800
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 1000 2: 1000 3: 1008 4: 1100 5: 1066 6: 1008
7: 1100 8: 1100 bogomips: 44798
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0c45:6a06 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Screen-1: 0 s-res: 2880x1620 s-dpi: 96 s-size: 761x428mm (29.96x16.85")
s-diag: 873mm (34.37")
Monitor-1: eDP-1 model: Sharp 0x1450 built: 2015 res: 2880x1620 hz: 60
dpi: 211 gamma: 1.2 size: 346x194mm (13.62x7.64") diag: 397mm (15.6")
ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:3165 class-ID: 0280
bus-ID: 1-4:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 2.73 TiB used: 857.16 GiB (30.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z44106
temp: 34.9 C scheme: MBR
SMART: yes health: PASSED on: 54d 10h cycles: 923
read-units: 22,381,068 [11.4 TB] written-units: 25,650,731 [13.1 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: ST2000LM003 HN-M201RAD
family: Seagate SpinPoint M9T size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0001 temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 36d 12h cycles: 5310
read: 5.27 GiB written: 6.2 GiB Old-Age: UDMA CRC errors: 103
ID-1: / raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
used: 31.69 GiB (3.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:3
ID-2: /home raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
maj-min: 259:3
ID-3: /var/log raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
maj-min: 259:3
ID-4: /var/tmp raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: zram size: 30.85 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 51.0 C pch: 44.0 C mobo: 41.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 282 Uptime: 3h 43m wakeups: 1 Memory: 30.85 GiB
used: 5.42 GiB (17.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1786 lib: 512 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-22
Last full system update: 2022-05-22
what we have to doo ? with this stack !!
i don't know whorry is in paste code but i we have malware in grafik card. proton- experimental in my Quake Live was gone i have 64 fps !!
Try changing the mouse speed in the system settings.
We are not responsible for malware.
New problem, new thread.
Since my translation programme has difficulties with your text, please write it in your mother tongue, too.
what a category in forum paste this code ?
Here, in this topic, is the right place.
There is clearly a language problem.
If someone can help this user in their native language, please send a PM to a moderator to re-open.
I don't even know what is OP language.
@Mordex47 post your issue in category #languages in your native language, so you have a better chance solving your problem.
