Screenshots of Garuda Linux
I'm not going to even try to lie - that's a pretty badass desktop background.
Thanks to whole Garuda team , you all guys are blazing fast !!!
I just found out about the application dashboard (full screen) and I will be using it instead of the application launcher.
To change do the following:
  • right click the application launcher icon (garuda icon) in the top left
  • select edit panel
  • right click icon again
  • select show alternatives
  • select application dashboard
can be easily reverted to the application launcher with the same steps except the last.
Welcome back :slight_smile:
OFF-TOPIC :smiley:
Making my dr40nized garuda sway more dr40nized !!! :smiley:
Yesterday I thought that now I will turn my pc completely to my taste ( so that, I will not need to touch my config files for at least 5 or 6 months )
And this the final result :
Now I can peacefully leave my craze of playing with config files for some time :slightly_smiling_face:
It's a great widget. You can also just drag it from the Widgets tray to wherever you want. I use it at the right-hand taskbar corner and log out from there. Very handy. Menu items easily arranged, too.
Try using it as your desktop instead of using a wallpaper. (Kind of makes it look like a bastardized GNOME shell.)
:wink:
EDITED to reflect correct referrer.
I thought that it is on KDE only :sweat_smile:
so do you mean that I can get it on sway too ?
( If I have said some stupid thing then forgive me :sweat_smile: , I am still diving deep in linux ocean :wink: )
When I was using KDE plasma dr40nized , I once tried it , And that's awesome thing in it. :smiley:
A very hard decisions , as I love may fancy wallpapers :sweat_smile:
I also used a small script to make the wallpaper selection random from my folder too , so that whenever I start my pc then there is a random wallpaper selected to display.
If someone wants then here it is :wink: :
set $wallpapers_path $HOME/Desktop/backgrounds
output * bg `find $wallpapers_path -type f | shuf -n 1` fill
And
Thanks @c00ter :smiley:
I apologize. I was commenting on @benjamin's screenshot and mistakenly referenced you. I have now corrected my post. However, yours looks very nice, also. I like it.
:smiley:
Current setup. :grin:
Large Pic
Simple clean desktop.
Large Image
Doing light setup on this one. :grin:
Wallpaper
Conky
Large Image
I like it darker :smiley:
Can you share the config files, please, maybe in new topic in #community:showcase ? :slight_smile:
Sway :slight_smile:
Wallpaper:
Love this setup SGS, way to match up colors. Just a beautiful desktop.
Having a bit of fun with sway I see. Happy me
Some color on this one. :smile:
Large Pic
