Wallpaper by @TilliDie
Just KDE
Yo I did it! (Achievement Unlocked
Fairly stock Garuda Hyprland (no G-Hyprland) with some tweaks I’ve made. Love playing around with the configs. I’ll dive back into Cosmic soon, but for now, happy with Hyprland.
Sleep, where art thou? So, I found an OK FF theme (gruvbox), turned the poor mess of colors I’d stumbled upon as, “Arizona,” into a comfy and useful color scheme, made some custom dark earthy KDE color schemes from that (above post is using Obsidian Coast (Sunset)), and then tweaked them to look good with different window decorators and application styles. Then, I tested different GTK themes to get something close enough, for the 2 or 3 GTK apps left that actually use the system’s choices, instead of the dev’s own. Finally, I hunted down an icon theme that’s not flat, not monochrome, uses warm colors, and has all the icons for a dark systray (Buuf). Amazing what one can accomplish, with a little insomnia.
Temp dark theme testing
Wallpaper video from wallpaper engine.
Icons: Slot-Dark-Icons
Cursor: Saturn
Theme: “individual parts of” Edna theme. Not the global theme.
what do you use to get movement in the wallpaper?
Arch I use wallpaper engine.
Nix I pull the MP4 files from the ones that have(wallpaper engine files) them that I find an use “Smart Video Wallpaper Reborn”
Good stuff man, good stuff.
I just have to ask,
I see on the site panel you have spotify… But Dragon Browser has problem to play DRM based content properly. Is it working for you normally?
I’m using the “real” spotify app for this. But you are right, DRM content was and likely will never be supported by FireDragon.
The cost of obtaining such a licence is just absurd.
