i am back after 3 month with a little bit upgrade ![]()
The good thing is
it is amazing that my new hardware automatically detected… and also no system break after 6GB+ upgrade ![]()
The bad thing is : my customization are about to broken ![]()
The good thing is
Cluttered, but you aren’t missing out on a wallpaper here. Because I made it solid.
Meanwhile I’ve been on a DE swapping spree and have settled on KDE until cosmic gets better at certain things!
Garuda COSMIC Layout 1
Garuda COSMIC Layout 2
You can literally make it look like however you want it to look.
Yepp, it’s looking good BTW ![]()
Would like to see how it feels after some realeses ![]()
Agreed it looks pretty good, and they haven’t even released first alpha yet (Aug 8). ![]()
Excited to see everything the community will built applet and app-wise, and what further customizations they’ll add.
It’ll be Gnome but actually good/better (my opinion).
Thinking of playing around with the theming and trying to get a Sweet-ish/Garuda look for it. Just need to have some more free time to do so.
What the ■■■■ am I seeing ![]()
( the wallpaper is from Sh**ting Stars (2022) - MyDramaList, and catppuccinified, in case anyone wonders
I do not typically leave octopi notifier running or even use it much, but here it is shown loaded, lol
Put all that in one folder. Then open an maximize it when needed. other then that it will look clean ![]()
what is that fullscreen app drawer?
Changed it up a little bit with my Plasma DE.
Candified WhiteSur/Ventura with Ditto menu and Wunderground weather widget.
I believe it’s Plasma Drawer but I don’t see any port to Plasma 6 on the GH so it might be something else.
Plasma 6 ver is here Ive been running it since it came out never had a issue. You can also get “launchpad plasma” off the widget store as well. It’s kinda like it.
Before that video went out I tested karousel its more for ultra wides but its super nice. Though I’m not into tilling, its still cool. lol
An there’s way better then klassy
Active Accent
And if thats not enough
KDE-Rounded-Corners just use the outline part of it an its in chaotic
For the browser set it to title bar an with that window decoration you’ll have no buttons or anything.
Spectacle, its built into kde.
