KDE 6
Does this mean there is a version of Win95 that works OK? Quelle surprise!
BTW, I am missing icons on two of my Hyprland installs.
Speaker and Headphones, like you. BTW, right click mute the mic.
That’s the correct view on the third. WTH, IDK which font is missing ![]()
My rounded corners are not correct, too ![]()
- + Adding CPU temp
Hyprland
"custom/weather": {
"exec": "curl 'https://wttr.in/Essen?format=2'",
"interval": 900,
"on-click": "yad --html --uri='https://wttr.in/Essen' --center --fixed --width=1000 --height=680 --timeout=60 --timeout-indicator=right",
Perfect time 15:15:15 ![]()
Mehh…for all these glassy things I switched to hyprland and there is swayfx, containing so many things ![]()
But Hyprland is according to my taste ![]()
Yeah but Sway is actually stable, and everything works. ![]()
Not everything ![]()
I am able to use preprietry drivers of Nvidia in Hyprland but was never successful in sway ![]()
It use to go into black screen or sometimes used to end in to kernel panic.
BTW, the way you use terminal encourages me to know more about Vim and terminal programms ![]()
Yeah Nvidia is a crapshoot on either one. ![]()
Remember when you had to launch Sway with the “--my-next-gpu-wont-be-nvidia” command-line flag in order to use Nvidia hardware?
Any program that has "--my-next-gpu-wont-be-nvidia" as a command-line flag is a good program in my book (more context in comments). - r/AyyMD
Yeah, other than that I tried many things but at last only hyprland worked ![]()
you’re using 3 different panel in top?
yes sir ![]()
My desktop always changes. I get easily bored.
But this one is a contender to stay on for a while.
The wallpaper is a picture of the day, thus changing daily.
