yeeaaaa. conky config pllleaseese
Out of date :smiley:
Check https://forum.garudalinux.org/t/show-me-your-conky-setup/
@freebird54 and others are better specialists than I am.
Installed KDE after over a year!
The only complain with this setup I have is the use of windoz icon for application launcher. Otherwise the setup looks gorgeous.
Doesn't the window(literal) look great for a launcher?
I don't know why you don't like :window:?
Are there any bad windows :thinking:, I don't remember...
Wait a second.
Are you talking about this? :face_with_open_eyes_and_hand_over_mouth:
windows 10 GIF
This one does look bad.
Summary
Had a hunch that someone would point this out.
It's been about two years since I used Windows. At first, didn't even realise I had put up a Windows logo for the launcher :sweat_smile:!
REpeNt! :crazy_face:
I like this one :slight_smile:
I used one of the Garuda icons for the launcher menu on my image build (not featured in my above screenshot).
Well yeah. Your application launcher looks exactly like what windows 11 has for it’s application launcher/start menu. Just windows uses a blue one.
I really wish forum had a blur image effect so that I could blur what I am about to post but well…
:warning: M$ sh*t ahead.
M$ windoz image ahead
Welcome back to the fold, bruthah!
maybe i will try to handpaint a wallpaper in the future for garuda, but iam so scared to fail, but if i wont try it never a picture will happen :smiley: , or i make a semi handpainted one combined with digital art :thinking: but i think it will be very colorful :slight_smile: have a nice week community :slight_smile: you rock
Awesome wallpaper.
thank you :slight_smile: its a modified version of draco, name is exodus, but iam unsure to post it should i ? :open_mouth: cause draco was meh for me so i made this one i have an other malefor version too but i dont think its better for me its better but idk :smiley: :confounded:
Never submit to fear! OK, almost never.
I’d love that as well. Seems to be blending with Sweet pretty well!
Hey mior, just wanna ask if it would be possible for you to share the cool garuda icon used in your fastfetch config. I know it might be something basic and easily doable but I am kind of horrible at it. :sweat:
I would really like to replace it here.
Wouldn't mind knowing the color scheme being used for the appearance inside the terminal either. :sweat_smile:
ahh hi :slight_smile: yeah the colorscheme is utterly-sweet but its a customized one from me and i post it on my gitlab and give the link just wait a bit :slight_smile: edit: do you know what for files should i post for the colorscheme its very haha shame on me i have a personal garuda edition and dont know right know the locations for the savings :,D
since you have edited it, it’s most likely in
~/.local/share/konsole/
with a .colorscheme file name extension.
It’s alright if sharing color scheme atm is not feasible if you can just share the garuda’s icon being used in terminal that would be fine too.
